Question about Panasonic TH-42PX50U 42 in. Plasma HDTV
PANY TH-42PX50U POWER WILL NOT TURN ON ,EITHER REMOTE OR MANUAL POWER SWITCH. PROBLEM IS INTERMITENT
  • egi7 Jan 03, 2009
    Turning the tv on gives a dull blue screen. When I try to affect the input by hitting the "tv/video" button, NOTHING happens. Sometimes, when doing this I get the list of different input options. Sometimes it stays blank. The only fix that has worked so far is to turn the t.v. off, unplug it, and replug it in to the wall..(default takes over?!!). This trick is no longer working. The t.v. is completely unresponsive. HELP!!!!
  • LEEV3 Jan 23, 2009
    I HAVE A 42 TH42PZ75U PANASONIC POWER WILL TURN ON
5 Suggested Answers
SOURCE:
jscruggs420
  • 36 Answers
SOURCE: Panasonic TH 42PX50U Red power light flashes 6 times
Most of the time when this happens it is the ysus board, that noise you heard was a capacitor popping. Another board runs about $175 and thats if you do it your self. A shop will most likely charge around 500-600, hope this helps, you could also try contacting panasonic and trying to get past the tech and onto casemanagement where you might get somewhere with an out of warranty fix.
Posted on Feb 07, 2009
jhinsincity
  • 616 Answers
SOURCE: push favorite button and get "self check"
If your panasonic has intermittent power issues the tv will require service, power supply needs an adjusment that should be done by a service tech, if not then you will need a power board. Julio [email protected]
Posted on Jul 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: Does anyone have a panasonic TH-42PX50U Service
www2.panasonic.com/consumer.../model.TH-42PX50U
www.nodevice.com/manual/.../panasonic/th.../get29233.html
www.panasonic.user-manuals.com/list-of-manuals-292-5104.html -
You can copy and paste any of these links into your address bar to bring you to your manual
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: My panasonic is not coming on,the power button is
Count how many times it blinks. Sometimes the problem is coded in the amount of times it blinks. If you see a distiction between blinks, say like 13 then a pause then back to 13 more blinks, google solutions for a 13 blink standby for your tv and you might be able to find the soultion.
Posted on Jun 14, 2010
How do i program a device using this remote
From what I can tell the EUR7627Z60 was originally shipped with the following Panasonic products: TH-37PX50U, TH-37PX50U, TH-42PD50, TH-42PD50U, TH-42PX50, TH-42PX50U, TH-42PX50UA, TH50PX50, TH50PX50U, TH-42PD50, TH-42PD50U
Here is the manual for the Panasonic: TH-37PX50U/TH-42PX50U/TH-50PX50U:
Panasonic TH 37PX50U Operating Instructions Manual
Best of luck!
Feb 03, 2016 | Panasonic EUR7627Z60 Remote Control
Tip
How to connect laptop to TV Panasonic TH-42PX50U
Hi,<br />i have TV Panasonic TH-42PX50U, but i don`t know how to connect it with laptop...<br /><span><span>Can I</span> <span>do it</span><span>?<br />because i bought cable and it doesn't works, when i connect they then on laptop is signal, but nothing happens on TV and laptop more... </span></span><span><span>I</span> <span>open the</span> <span>laptop</span> <span>program</span> <span>but</span> <span>there's</span> <span>no evidence to show... <br /><br />i hope somebody can help me!<br /></span></span>
on Dec 18, 2010 | Panasonic TCL42D2 42 in HDTVReady LCD TV
On/Off are the only functions that work (from either the remote or buttons on TV. Replaced the key,button,IR sensor board. No change. Where do I check next?
Check the manual for the tv and see if there is some kind of lockout code which is usually used to restrict kids from watching certain things. If not that, check to see if the remote board and other power supply points are actually have some voltage present. Could just be a dirty contact on the board too, or a small break in the board.
Nov 30, 2015 | Panasonic TH-42PX50U 42 in. Plasma HDTV
I have a Panasonic HD 1080 P 42in. plasma model # TH-42PX50U. It won't turn on and the power light flashes twice.
Is it still under manufacturer's warranty?
Did you purchase it with a "double-your-warranty" credit-card?
There's nothing that you can fix yourself.
So, either $100 to $300 at a TV-repair shop,
or responsibly recycle it, and buy a replacement.
Oct 31, 2014 | Televison & Video
I have a Panasonic TH-42PX50u that suddenly is stuck on one channel and no volume control either. Same whether using remote or on TV. Only turns on and off no other control.
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable. Look for jammed buttons on remote and/or on control panel. Try removing the batteries from remote and operating from the control panel of TV. If these are ok, Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 06, 2012 | Panasonic TH-42PX50U 42 in. Plasma HDTV
My panasonic is not coming on,the power button is just flashing red(TH-42px50u)
Jun 14, 2010 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Does anyone have a panasonic TH-42PX50U Service Manual I could download?
Aug 25, 2009 | Televison & Video
Push favorite button and get "self check"
Jul 26, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Feb 06, 2009 | Panasonic TH-42PX50U 42 in. Plasma HDTV
Panasonic TH-42PX50U 42 in. Plasma HDTV Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
