Question about Whirlpool LHW0050PQ Front Load Washer
Doesnt wash properly
I just bought a condo with this washer in it. when I fill it, and select my modes and start it......it barely fills, then runs in one direction for 3 seconds, stops and goes the other direction for 3 more seconds and repeats this entire process, not washing the clothes......the LEDS seem to indicate the mode, any ideas
  • flyboycj84 Dec 01, 2007
    Ok so heres what really is happening with this thing upon watching the thing closely......I drained the existing water and started over. I selected the Normal wash cycle, with extra high spin as the manual recommends. The maching fills with water (hot and cold it sounded like) about 2 inches up the glass on the front loader (i dont know if this is the normal level with these machines) It then starts to wash in one direction for a bit, then stops and goes the other direction. It did this for about a half hour.....(WASH LED illuminated the whole time) then the machine stops, and the LED changes from WASH to a flashing DONE, and thats it!!!! still with the same water it initially filled with
    No draining, no rinsing no spinning!!! and the door stays locked.......
    so what gives???
    President:
  • 1,294 Answers
Check the inlet screens on both sides of the pipes. (Plug off the wall first) Open your inlet full before wash. Check outlet filter to clean out, check to see if any debris in pump. Is this machine second hand? If so you can download a manual.......
Posted on Nov 30, 2007
  • prem mathew Nov 30, 2007
    Click on (Whirlpoor or whatever your brand is) below FIXYA on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
    And dont forget to rate me........
  • prem mathew Dec 02, 2007
    Click on "troubleshooting" above for your model, i am having a serious prob with my internet......
SOURCE:
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My neptune TL stops at 11 minutes and flashes "nf"
mattscott;
My comments are based on the FAV6800A/FAV9800A.
NF = No Fill. Your machine has reached a Control Board internal timer and has not seen proper signaling from the Pressure Switch for expected water fill for the wash cycle selected.
Possible fail points.
1. Pressure Switch is not signaling for properly tor water fill.
2. Water inlet valve is restricted or not functioning.
Please confirm your machine model number is it a FAV6800A or FAV9800A? I’m going to assume your machine model is a one of those models. Here is a link for the FAV6800A/FAV9800A Service Manual.
If you can let me know how much water is in the wash basket when your Control Board triggers the no fill error “NF” to the display? I would prefer you select Quick Wash cycle with minimal machine settings for the water fill. Do you have the issue with a cold temp select fill, a warm/hot temp select fill?
If you want to DIY I would suggest you become familiar with how to get in Service Mode. We may need to go to page 16 of the SM and possible check for correct Pressure Switch transitions in Board Functional Test Input Control Keys.
We will continue after your feedback…..Rich
Jan 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Maytag washer water doesnt stop
raise top or remove front panel(can't remember which) rear corner left small hose attached to connector on tub pull and clean probably plugged up with crud also ck connection on tub
Dec 12, 2008 | Maytag HAV3460AWW Top Load Washer
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer leaks when running full loads
This could mean the fill level is not working properly and there is an overfill situation. Generally[I don't know 'Roper'] the fill level is controlled by a 'bottle' like device at the fixed to the outside of the drum at the bottom with, with a fine tube leading to a disk like thing near the top of the machine- with wire coming from it to the controller. The 'disk' thing is the pressure sensor. and the bottle thing is supposed to fill with water and the air pressure in the tube actuates the switch in the 'disk' Overtime the 'bottle' will get clogged with crud and need cleaning out. This will mean taking it off and giving it a good cleaning. Hope this helps.
Jul 07, 2007 | Roper RAS8445KQ Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
64 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
