Question about Turboair Turbo Air Sandwich Salad Table 72" GSP-72T
Broken Sandwich prep thingywhatzit
My 3 door sandwich prep fridge is not working. It is plugged in, circuit breakers ok, switch on...nothing. any ideas??
Bad thermostat
Posted on Dec 06, 2007
SOURCE:
True prep table leaking water.
The drain tube that drains out the water is plugged. It runs from inside the cabinet to under the refrigeration unit outside the cabinet. Try to clean it out with a can of compressed air used to clean keyboards and see of that works.
Sep 19, 2016 | True TSSU-48-12 - 48 Sandwich Salad Prep...
Metalfrio prep table freezing evapoator
Check that all vent areas are clear of any dust or food packaging. If you have ice build up it needs to be thawed out also because it will only continue freezing until it gets proper airflow.
Sep 17, 2014 | Metalfrio SCL2-60-16 Salad Sandwich Prep...
Need door gasket for Jimex cold tech model S1BRR-06S
Cold Tech gaskets can be obtained from Case Parts Co. 800-421-0217 or RHS Parts 800-537-8300, per jimex corps final technical spec. sheet. I hope this helps.
Apr 02, 2014 | True Refrigerated Sandwich Prep Table 72"...
Freezing
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
Mar 27, 2014 | True Refrigerated Sandwich Prep Table 72"...
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
True prep table won't hold refrigerant
Have the unit leak test after pressurizing with "Nitrogen"
Jun 03, 2011 | True Refrigerated Sandwich Prep Table 72"...
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
I got a true refrigeration sandwich prep table it will get down to temp. But as soon as it gets down to about 38 it will start frosting up all the way back to the compressor and by the next day it has...
Look for doors not properly closing, poor air flow over coil or something blocking air flow, improper freon level.
http://www.truemfg.com/pdf/InstallManuals/TPP_TSSU_TUC_TWT/tuc_english.pdf
check out this web site as it has a manual for your equipment. it has lots of good info. Hope this helps. If you need more help, let me know.
May 19, 2010 | True 598-TSSU608ADA SandwichSalad Unit 155...
Microwaved a sandwich from Wendy's-apparantly it had tinfoil wrap
There is fuse in the back somewhere around where the cord comes into the unit.My guess the fuse is blown
Mar 15, 2009 | Kenmore 62622 Microwave Oven
Turboair Turbo Air Sandwich Salad Table 72" GSP-72T Logo
325 people viewed this question
Top Turboair Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Turboair Refrigerator Expert? Answer questions, earn points and help others
