Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag mah4000 washer
Washer will not start - that is there must be relay that engages to start washer and it is not working. If I hold the start button in continuously it runs ? Please advise - think main circuit board is bad - Do U know where I can get a schematic of this board ? Looks like Q3 on this board is burnt. Thanks, John
  • John Schuholz Nov 30, 2007
    Board replacement is out of the question - If an amateur or repairman can't fix these boards - this appliance is junk. This board costs $150 or more. When a company designs an inferior product - the least they can do is supply the schematic so customers can repair there problem. Thanks
  • 833 Answers
Ajshoe,
I'm not familiar with this particular model but I will tell you this:
The schematics for these circuit boards are generally not published. The reason is that the average repair guy will not want to fix them and probably lacks the expertise. Q means transistor. Transistors are 'relays' after a fashion. If you can see a number, you may be able to access a replacement. Otherwise, I would change the board. The fact that the washer will start sounds like the relay that the board controls is operating properly.
You may be able to find a board renewal/exchange online for less than a whole new one. Be sure to unplug the machine and ground yourself when handling the board.
Posted on Nov 30, 2007
Model MAH4000, will not spin out, door lock will
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
May 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Mah4000 maytag how to locate remove and clean
if you think your problem is a dirty sump run a good quality appliance cleaner trough it first much easier than stripping down machine give it a go
Nov 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Mah4000 won't go into spin cycle. drain pump is working, but no high speed spin.
Hi, this is MCU damage. This is called the Motor Control Unit. it manages the spin cycle in your unit. it is damaged at this time. replace it asap.
Jun 25, 2009 | Maytag Neptune Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
MAYTAG Mah4000 front loader washer
HAVE YOU CHECKED THE MOTOR CONTROL BOARD?IT IS LOCATED INSIDE THE FRONT RIGHT BOTTOM OF WASHER BEHIND FRONT PANEL,LET ME KNOW IF YOU FIND ANYTHING-MIKE
Nov 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Broken Tub Support Arm
ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Mar 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
My machine (Maytag MAH4000aww) failed to drain because of a bobby-pin that was lodged in the drain pump impeller. Because of the added weight of the wet clothes, and the undrained water; the machine would not spin. The Wax motor worked as the door did lock properly, but the machine would "ramp up" trying to spin, but would stop the process when it sensed that the load was grossly unbalanced. Check the drain pump to see that it is not clogged or that the impeller is not impeded by a foreign object before spending money on imbalance switches! I will now cancel the service man, who surely would have charged me for a new pump, plus the cost of the visit, and now I can stop swearing! My wife is glad she married me!!!!
Rene Marchand (Beaumont Alberta)
Jan 13, 2008 | Washing Machines
MAH4000 washer
VERY BIG JOB!!
This job requires replacing outer tub. If you want, I can spell out whats involved. Expect at least a couple hours and a pretty large parts bill. Let me know!!
Nov 15, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
