Question about Cuisinart Coffeemakers
Leaking cuisinart grind and brew
My Cuisinart grind and brew coffee maker is leaking under the unit during brewing. Not a lot. About 4 ounces. Is this a permanent failure in the water basin or can it be fixed?
  • 6 more comments
  • gthaxton Nov 30, 2007
    My cuisinart grind and brew stopped grinding first and the leaks followed. It leaks about 1/4 to 1/2 cup of water whether I am making coffee or not. One evening I charged it up for a timed brew the following morning only to find that much of the water had leaked out over night. Can this be fixed? If so, how?
  • Anonymous Dec 17, 2007
    12 cup grind and brew clear water leaks out from under mach when stored in res.. about half a cup mach is 2 yrs old is this worth fixing
  • BrookBusbee Dec 24, 2007
    Clean in dishwasher, run vinegar through- no help. I am beginning to thank that the springs on the mechanism are ahot. Advice?
  • jod9 Feb 29, 2008
    My Cuisinart grind and brew is leaking during brewing. The water has gotten into the electrical part and is causing it to short out. Any way to fix this?
  • maggiequest Dec 21, 2008
    Same here, but on the Cuisinart Filter Brew.
  • kbustos Jan 31, 2009
    My grind and brew will not drain into the pot. It overflows all over the counter.
  • Pegisu Jun 23, 2013
    I had the same problem and eventually discovered that the top piece of the carafe has a movable piece of plastic that gets clogged with coffee sludge. It serves as a baffle and when it clogs the coffee does not drain into the pot but leaks over the pot and appears to be leaking from the bottom, but in reality it is not. Trust me I sat and watched it brew. Regular cleaning did not work nor putting the top of the carafe in the dishwasher. What did eventually work to clean that baffle was to soak it in full strength simple green overnight until the coffee sludge dissolved and unstuck the baffle and allowed it to move freely. Now when I clean the top I shake it to see if it moves freely, if it does not, then I soak it again. So far this has been working.
  • Anonymous Apr 01, 2014
    A Small Blue rectangle WARNING. It appears on mid top towards the LEFT side of the brewing unit on screen and water does not flow to process the coffee after grinding. Normal flushing does occur however, e. g.. on start up.
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
We had a major problem with the unit leaking as well. Sometimes it didn't leak, sometimes it did. Sometimes it appeared to be leaking from above the thermos, sometimes looked like it was coming from underneath the unit. After trying out many different things to try and fix it, turns out the problem was the lid of the thermos. There is a little ball in the lid that needs to move around for the water to get through, it was kind of stuck from hard water deposits and I assume coffee residue. Its impossible to completely clean because you cant take it apart. We tried to clean the unit and lid with vinegar and CLR (ran through coffee maker according to CLR instructions), and it did work (the little ball inside the lid started to move and "click" again) and stopped leaking. But we decided for a more permanent approach and we purchased replacement lids for both the thermos and brew basket, both items with delivery from Cuisinart's website was about $20. No more leaking, thank God!! *AND* the coffee is once again absolutely delicious.
Posted on Sep 21, 2010
    New Friend:
Our coffee pot was doing the same thing. We soaked the carafe lid in full strength Simple Green overnight and it dissolved the sludge that had formed. The carafe lid can be separated into two pieces and you only have to soak the top part with the baffle in it. When you shake the top if the baffle does not move freely it is time to soak it again. So far this has been working.
Posted on Jun 23, 2013
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart Grind and Brew is only making 4 cups of coffee. Can you help us to fix this? We've turned off the 1-4 cup button...but its still only brewing 4 cups, we have to hit brew again in order to get...
Another possible reason for backup - using paper/gold tone filter at same time. If not:
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Nov 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
The grinder works, the on/off light comes on, but no brewing???
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker
Clean with vinger/water first before giving up
-Tha Mp3 Doctor
Oct 06, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Oct 04, 2007 | Cuisinart DGB-500 Coffee Maker
Machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Jul 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart Coffeemakers Logo
9,057 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Marvin
Marvin
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
