Question about DVD & Blu-Ray Players
Movie won't play!!!!!!!!
It won't work!!!!! When I insert the disc the screen shows the following: Read, then invalid key, then error and then no disc. Go figure. The battery is fully charged. It seems the disc is just spinning around and then it slows down and then it starts up again and then it slows down. Please send reply to
  • 75 Answers
SOURCE: DVD gives an invalid Disc Error
It's possible you have a bad DVD player unit and it will not read any type of DVD disks.I have had a lite on DVD player before and no matter what type of DVD I put in it.It wouldn't play.It only played CD
Posted on Jun 01, 2009
SOURCE: Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. if anyone can help.
Posted on Jan 14, 2008
  • 1003 Answers
SOURCE: Unknown disc error message
Posted on Feb 02, 2008
  • 52 Answers
SOURCE: After inserting disc screen shows loading but
take it apart and clean the lens that reads the disc with a q tip and nail polish remover and that should solve the problem
Posted on Jul 03, 2009
  • 1447 Answers
SOURCE: Discs won't play.
please change laser unite then solve your problem
Posted on Sep 09, 2009
SOURCE: Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
19 July 2010
Posted on Jul 18, 2010
0 characters
1 Points
Vizio vbr210 error 11000404 How do I update firmware to watch newer blu ray movies?
I had the same problem -- we even returned the disc and got a new one. Go to the Vizio site and download the firmware for your player. Put it on a USB stick and plug it into the player. Follow the onscreen instructions (basically just press OK). The entire process takes less than 5 minutes from download to finish.
The Hunger Games works perfectly now.
Aug 21, 2012 | Vizio VBR210 Blu-Ray Player
It is not playing any dvd's. It says invalid or
Follow the steps below to troubleshoot if the BD player cannot read or play a disc:
1. Ensure the Easy Setup procedure has been completed on the BD player.
NOTE: Can't play DISC may display on the LCD screen if the Easy Setup procedure was not completed first.
2. Ensure the inserted disc is compatible with the BD player.
NOTE: Consult the instruction manual of the BD player for a list of compatible discs.Manuals are available online through the Manuals/Specs/Warranty link on this page.
3. Select BD players may require that a USB memory device has been properly inserted into the EXT slot of the player prior to playing the movie. If the BD player being used does not have an EXT input, skip this step.
NOTE: The USB memory device may need to be re-formatted to FAT32 format prior to inserting it into the player.
4. Use a soft cloth to clean the disc.
5. Examine the disc for any cracks or scratches that might be interfering with playback.
6. Attempt to play another disc.
NOTE: If another disc plays in the player, then the previous disc may be faulty. In this case, contact the Customer Information Service Center at 800-222-7669 to speak with a customer service representative for further troubleshooting.
7. Remove the disc from the BD player.
8. Turn off the BD player.
9. Unplug the power cord of the BD player from the electrical outlet.
10. Let the player remain without power for 1 minute.
11. Plug the power cord back into the electrical outlet.
12. Turn on the BD player.
13. Insert the disc into the BD player.
14. Attempt to play the disc.
If the issue is not resolved even after performing these steps, then try installing the latest Firmware update if you have not done yet.
Here is the link to download and install the Firmware update.
Select the correct Operating System and download the Firmware update.
Then follow the instruction on the same to install the update in the Player.
If the issue is not resolved even after installing the update, then Playe may require service.
Jul 21, 2010 | Sony BDP-S360 DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
This is quite easily, cause by ONE reason. The thing is, the lens is very very dirty, or had broken, try to replaec it if u can, or try cleaning it with cotton.
Mar 30, 2009 | Lite On LVC9006 DVD Player/VCR
Disc Reading Error
my remote wont work recorder
Mar 24, 2009 | RCA DRC8300N DVD Recorder/VCR
Wharfedale DVD- 265 saying invalid disc
Check and see if there is dust or dirt or something on the lens. Dirt, grease and fingerprints will cause a DVD player to have read errors.
If it a new player, or under warranty, get it replaced. It sounds like it is failing.
Hope that helped.
Jan 01, 2009 | Wharfedale DVD & Blu-Ray Players
RCA DVD player model DRC105N that won't read discs anymore
If the DVD is not reading any CD, then it is often a lens problem.
If th lens cleaner does not work the unit must be taken apart, to clean the lens pickup with isopropyl alcohol and soft cotton tips.
In some case is necessary to replace the lens pickup, as this is defective.
Nov 26, 2008 | RCA DRC105N DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dvd play back blue screen
I recently got the same problem on this model. The component outputs still work but I don't get video or audio on the baseband outputs. I emailed Sony support and they said take it to a repair center. Am still looking for a solution.
Nov 01, 2007 | Sony DVP-NS300 DVD Player
Plays CDs but not DVDs
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
Mar 12, 2007 | Panasonic DVD-RV31 DVD Player
DVD & Blu-Ray Players Logo
119 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
