Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Konica 7222 f28-3 code
What is the part # for the t/s unit & the casings for the konica 7222.
    Problem Solver:
  • 5 Answers
Part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Posted on Sep 02, 2009
    New Friend:
I have a problem my printer jams all the time its says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no 5
Posted on Mar 15, 2013
SOURCE:
MACHINE HAS CODE OF F26-3. HOW DO I FIX THIS CODE?
replace the developer and run required procedures. either that or the senor that monitors the developer and toner mix is bad worse case the control board the sensor send signal to is bad
try this web site for developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 01, 2015 | Konica Minolta Minolta 7222 Laser Printer...
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 11, 2014 | Konica Minolta Bizhub 7145 Copier
Konica Minolta Bizhub 7222 scaner don't working N-37
Does it print?, Can you ping it. Scan to Email or PC? Or SMB/FTP? Check mail server. also try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Feb 14, 2014 | Konica Minolta Office Equipment & Supplies
Connection cords needed for konica 7222 to laptop
try a computer store
Side note that machine will work with XP or before!!!!!
Jan 07, 2014 | Konica Minolta Minolta 7222 Laser Printer...
What cords do I need to connect konica minolta to laptop
That a big machine, will only work with xp or before, try computer store
Konica monilta 7222 error f-35-4
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Jul 19, 2013 | Konica Minolta Minolta 7222 Laser Printer...
CODE F51_2
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Jan 04, 2012 | Konica Minolta Office Equipment & Supplies
My konika 7222 coded f-26-3, the l detection is 0006 then 065, it does not run now
*for the code f-26-3 theirs a problem with your toner box or toner unit, if it doesn't drop in it's toner cycle...try to check the toner box motor if it still functioning, and if not so, then you must have to replace the toner box motor....
*sometimes rust in transfer unit can cause with that code..try to check first the terminal of the transfer unit...
just try my solution & explore....adios!!!
Aug 27, 2011 | Konica Minolta Office Equipment & Supplies
How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
Oct 01, 2009 | Konica Minolta Office Equipment & Supplies
Will the fk-102 fax kit work on konica 7222?
the 102 will work but not all the features will work like with thefk103
Feb 20, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
647 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
