Question about Canon PIXMA MP150 All-In-One InkJet Printer
Waste ink absorber
The wast ink absorber is full. I cannot change the ribbon
  • 9 more comments
  • Anonymous Dec 05, 2007
    Canon IR1670F copier....LED states 'waste drum full. Prepare new drum;. Seems like there should be a way to empty the waste toner out and be able to continue using cartridge until the toner is empty.... Is this possible?
  • akhmal May 16, 2008
    my canon pixma mp150 cnnot be used anymore. it is always show the warning blinking led on my printer. is this my printer ink absorber full? please help me
  • mnicho May 19, 2008
    Canon Pixma MP150 Waste ink absorber full message. At the moment it still works when you repress the start button but message appearing much more frequently . Instruction guide says take to Canon Dealer but have been quoted amounts to fix it that are more expensive than a new printer .Is there an easy fix or should the printer be binned and one from a different manufacturer bought.
  • Anonymous Jun 14, 2008
    Have tried maintenance to clean rollers but not successful. What now?
  • FLTOW GIRL Sep 26, 2008
    I had the same problem for my waste ink absorber, So i googled my problem and low and behold you solved my problem,... (except for the hands on part, by two brilliant women.) Thanks for everything
  • naughty_nic Oct 09, 2008
    Bports you are a GOD! Thank you so much for the info!! You saved me! It worked like a charm! I wish I could give you a great big hug! Thanks again -Nicole
  • chen hong
    chen hong Oct 13, 2008
    I cant clear the waste ink absorber (E27).
  • Anonymous Nov 26, 2008
    ink absorber full
  • JPlloyd Feb 26, 2009
    My Canon IP3000 is full on the Ink Absorber and I cannot print.
    How can I fix this problem?
  • Anonymous Apr 17, 2009
    bsports! You DA MAN! Thank you so much! You are appreciated!!
    PEACE!
    Derek D.
  • kiatoa May 11, 2010
    cleaned the pads but I have an error of 5800. Please help.
    [email protected]
This is actually a very easy fix. Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers. Now you may have to reset the error message so you can get back to printing. This is how to do it.How to clear E27 Code
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
  • Turn off the printer.( it must be turn off) then turn it on again.
Posted on Jan 23, 2008
  • Shirley Apr 21, 2012
    Wow. My printer has been packed away for almost a year now, if not more. since am in the islands and we do not have a canon dealer here, and one local technician said to me that my printer may be dead, i gave up hope. but lo and behold! as if by some divine intervention i decided to google this waste ink absorber thing and in a matter of minutes, my printer is printing again. bports, you are a Godsent and I bless you. thanks a million.
Where can i buy canon waste ink absorber?
Posted on Oct 28, 2008
  • 1 more comment
  • bgceco Dec 29, 2010
    I stripped my MP150 and it wasn't a pleasent job, but that's the only way to clean the waste ink absorber. Do not recommend to anyone to buy this printer but if you are in the same situation look at this video how it's done: http://www.youtube.com/watch?v=X75PIz9_Q...
    I stripped my MP150 and it wasn't a pleasent job, but that's the only way to clean the waste ink absorber. Do not recommend to anyone to buy this printer but if you are in the same situation look at this video how it's done: http://www.youtube.com/watch?X75PIz9_Q6s
Don't understand the change the ribbon comment but I have had a similar problem with waste ink absorber on another Canon printer (and lots of other people have.. there is a web site dedicated to fixing printer problems and this is a common one) You need to get a SERVICE manual -not the user manual you get with the printer- I got one for mine by doing a web search and buying one (mine was approx 5USD). In it you can get a code which you put in to reset and it will get rid of the waste absorber message and allow you to use the printer. I wouldn't do the reset more than once - the waste absorber is a pad that collects the ink from the head cleaning and if it gets too full of ink it could leak and damage other parts of your printer (or mark your furniture). Canon tell you to get the printer serviced when you see this message! If you get the service manual it gives you instructions on how to take the printer to pieces and change the pad...depends on how keen you are!
Hope this helps...I now wouldn't buy a new Canon printer because of this problem...Good Luck
Posted on Dec 06, 2007
Thanks bsports, I'm now covered in **** and the bits have fallen into the printer. Thanks also to Cannon for surprising me with this ****. You can shove your printers from now on.
Posted on Jun 15, 2009
You can get at what I think must be the waste ink absorber tucked away on the right, in the front. What about usi a twist of absorbent paper or cloth and repeating as necessary?
Posted on Jan 21, 2008
SOURCE:
SOURCE: how to reset waste ink absorber full ip3300 warning?
I have the same problem, but Jet Tec waste inks. When I first replaced black (pgi 5bk)-don't forget to place the small chip from the original cartridge to replacement; it worked fine. But now, it has a lot of problems because this **** printer from canon only want original inks (and the original are tooooooooo expensive). I'll never bought anything else from canon.
Posted on Mar 23, 2008
ginko
  • 19396 Answers
SOURCE: Waste Ink Absorber full - Canon Pixma
Reporting solution by daweed:
"WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEM
This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
Here's the fix:
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
I did this and it works fine! No more error messages and so..."
Posted on Mar 13, 2008
SOURCE: canon printer mp160 e27
E27 Waste ink absorber full or platen waste ink absorber full please chek it
Posted on Oct 08, 2008
wanali
how can i get my ink absorber to be unful and work agian so i can print again WANALI
Posted on Oct 11, 2008
SOURCE: E27 Waste ink absorber full
canon mm140 E27 = Waste ink absorber full or platen waste ink absorber full what would be made to solve this problem
Posted on Dec 21, 2008
Ink absober is full
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
Jan 11, 2011 | Casio Office Equipment & Supplies
How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
firstly download MPTOOL
Download here
Download manual guide how to use MPtool
download here
OK hope this can help
Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Ink waste absorber is nearly full. What do I do?
You need to reset it.
E3-3 = Paper jam
E4 = No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
You need Mptool to reset your mp170
download mptool here
Manual guide to use mptool
download manual guide here
Jul 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Full ink absorber
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Apr 08, 2009 | Canon PIXMA iP1600 Printer
Dec 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber
You'll always find the wast ink absorber under the printer head after printer head prints and rest, there is a rubber type clip which cleans the head and the ink drips down on the cushion absorber. Disassemble the printer and remove the cushion than dip in the bucket of water until ink dissolves out of the cushion and wash under running tap until clean then dry and finish, put back the item and assemble the printer.
Nov 06, 2008 | Canon Pixma MP450 All-In-One InkJet...
Waste ink carterage full
You have to send it to your nearest service centre.
Nov 03, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
6,552 people viewed this question
Clive
Clive
old marine
old marine
Ekse
