Question about Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
I have had the ViewSonic VX924 for about 1.5 years. Just this morning when I moved the mouse to wake up the monitor, the screen flashed an image for a split second and then went blank. However, I noticed that the green LED flashes as well. I have plugged in other computers to the monitor and all display the same result. They work fine on a different monitor. I have read in the manual a working that too high a resolution and refresh rate can "permanently damage" the monitor. Any help appreciated. I'm not sure if I even chose the right monitor as my product. But I have had a KDSusa monitor that would go black when I booted it up. If I turned the monitor off then back on it would display an image for maybe 2 seconds tops then go black again. I sent it in and they sent me a diff. monitor. This one did the same thing after having it for a while. My dad said the brand must be cheap so he gave me his 19" LCD. This monitor I had for a few months and it has started the same thing but this monitor if I turn it off then back on about 5-6 times it will stay on. What could this be?
  • 21 Answers
Have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Posted on Jul 13, 2009
SOURCE:
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Viewsonic Optiquest Q19 blanks out - just a year old
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
My ViewConic Monitor has exactly the same problem as this another post? HELP!
Does it come back if you lower the resolution to the lowest and make sure the refresh rate is at 60 Hz?
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
May 02, 2007 | ViewSonic VX924 19" LCD Monitor
Sceptre X9G Komodo IV 19" Flat Panel LCD Monitor Logo
430 people viewed this question
Top Sceptre Computers & Internet Experts
Ekse
Ben Slimene Aymen
Ben Slimene Aymen
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
