Question about Philips (JR4DVDRWK/00) DVD+RW Burner
CD DVD player keeps ejecting tray
I have a Philips DVD+RW SDVD8441 in my laptop it keeps ejecting for no reason. usually when I move it or get on the internet. What could cause this?
  • 1 more comment
  • trinipapee Mar 21, 2008
    I have a Gateway Notebook MX6920 with a PHILIP DVD+-RW SDVD8441. The dvd rom keeps ejecting, sometimes at startup or when I put a cd or dvd it starts and after about a minute or so it stops and ejects or if I hit the laptop it does the same thing. Can it be the settings or a virus?
  • n00ne May 11, 2010
    You most likely have a virus. It shouldn't cause any harm to your computer its just extremely annoying. You will have to end a process in Task Manager. I'll try and find out what its called. Does it eject everytime you use your computer or only sometimes. If it's everytime you start up your computer that it will be something in the startup folder most likely.
  • Anonymous Mar 15, 2014
    philips dvd rw sdvd8441 driver
    Scholar:
    New Friend:
  • 67 Answers
Don't know for sure but if the common reasons are that it opens when you move the laptop and when you get on the internet the power to the device may be changing when these actions occur. Moving it may cause an intermittant connection and getting on the internet usually draws more power from the power supply. If the batteries are ok the power supply voltage may be at the threshold at which these events make them fall to some value where the dvd burner thinks it's getting a message from the operating system to eject. Try it on a different computer and perform the same actions. If the problem stays with the burner it's the one with the problem, otherwise something in the laptop itself may be causing it.
Posted on Nov 30, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
Solution #1 surely is the correct.
I've had the same problem and definitely is not a virus. Tho others are missing the fact that it occurs when the laptop is moved. What Falling Down says fits perfectly. Could be a moving connection, or so. Taking off the drive and cleaning the terminals could help.
Ooooops. Now I see this question is from a long time ago. However, it could help somebody.
Posted on Feb 11, 2010
The problem is a corrupted driver file. uninstall and reinstall the driver.
Posted on Oct 21, 2008
  • 76 Answers
I think your laptop Some virus Problem check antivirus ok by
Posted on Apr 21, 2008
My LG multi dvd writer lightscribe tray wont open. the green light is steady. no matter how many times i try to eject the tray ang it wont open. there is dvd+r inside.
use a unfolded paperclip and insert it into a small hole below the disc tray. This is the manual eject port. Stick it straight in and push, a little bit of pressure will be needed.
Apr 20, 2009 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
I am probably doing something wrong. I want to use a DVD RW to store data but it seems the MS Media center is all I have. Is there a way to use these types of removable storage like a CD-RW? Could I need...
You can use programs like Nero to burn data onto a disc such as a CD-RW. Since you already have a DVD burner you can even use a DVD-RW to burn your data
Aug 26, 2008 | Computers & Internet
Replaceing a philips dvd rw sdvd8441 in a laptop 1. How can I remove Philips dvd+-RW SDVD 8431 from my Fujitsu Siemens Amilo M 7405 laptop? 2.Where can I find a compatibily new one? My product type is:...
what happened to ur current drive is it not reading the dvds why dont u try cleaning like this
open the dvd tray u see that eye like shiny thing clean in circular motions gently with soft cloth or tissue and try the dvds see if it reads it is a normal remedy otherwise change the drive if it doesnt help
normally there is one screw below the dvd drive i mean just beneath just take it out and pull ur whole drive unit out not just tray whole drive and replace it with any drive on ebay u can get it around 50 $ u can also fit any brand not just philips but u should look out for the bezel design (front panel ) u can also flip the front panel with the new one if all dimensions are same normally this slot is universal in size hope it helps u can ask for more
pls rate me FIXYA for help
Mar 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Phillips DVD+RW burner on Dell computer won't eject
You will find a small hole on the face of the drive. This is the manual eject mechanism. Insert any wire-like object (a properly sized size paper clip works real well) and push until the disk ejects.
Note: Many times the mechanism is recessed quite far behind the face plate, so make sure the object you use is long enough (again, paper clip).
"Today's the best day of my life...and NOW you're part of it!"
Dec 13, 2008 | Philips CDD 4801 CD-RW Burner
Philips DVD /-RW drive, model SDVD8441 not working
well go to google.ca and type DVD/RW drive model SDVD8441 driver free download.
thats all i did when mine failed.
Oct 02, 2008 | Computers & Internet
I have a Gateway® M-6878h laptop computer, Whenever I put in a DVD or CD into the disc tray and try to eject I get an error that says "An error occured while ejecting DVD RW drive E:" and...
Hey,
There is a small hole in the cd / dvd drive tray, you can use a needle or something small to push in, it will eject the drive tray and the cd.
Thanks,
Ekse
Aug 30, 2008 | Computers & Internet
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
DVD-Rom drive doesn't work.
right click my computer .. manage.. storage.. disk management. unalocated. its totaly empty . create partition then format it ntfs and name the volume uhhhh USB160GB for easier to recognize
May 17, 2008 | Maxtor Hard Drive
Philips CDD 4801 CD-RW Burner cycles
Is this covered by a front console cover type or is the dvd, as it is with it's own eject button, as it may be touching the front eject button.
Jan 15, 2007 | Philips CDD 4801 CD-RW Burner
Philips (JR4DVDRWK/00) DVD+RW Burner Logo
1,652 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
