Question about IBM ThinkPad T20 2647 Notebook
IBM T40 Hello,My IBM T40 crashed and will not start at all-not in safe mode, not with the Access IBM button, etc. It started crashing unexpectedly (screen went dark etc., and has progressed to this state.I was able to start it a few more times by unplugging the battery, waiting, and starting the machine in IBM mode, but none of this works now.-I have taken the machine apart and reseated the connections. ANd tried F1 and the two monitor F key, but nothing works. Any help would be greatly appreciated. Thanks
Thanks for your response Ron.
I just tried pressing down hard while trying to boot--nothing happened.
I tried this first as the the computer only has the original/internal memory-which requires taking the whole machine apart. I'll try that in a little bit--in the hopes that if you happen to get this message soon you could please let me know if I should still take the machine apart given the fact that I only have the internal memory module.
Best,
Clay
Posted on Nov 30, 2007
    Sergeant:
  • 324 Answers
Well, Clay, sounds like you are in a bit of a fix! Let's see what we can do about it, OK?
To start with, I have a couple of things for you to do so that we can get a little better handle on just what's happening.
First, let's remove the battery, all of the memory and the hard drive. Then replace one of the memory modules and see if it doesn't try to come up. Whether or not it tries to come up, go ahead and replace the hard drive and the other memory module and try to bring it up again.
This exercise may be all that is needed to get it fixed. If not, then continue on.
Secondly, I need you to try to power it on while you press down firmly (really press down) in the area just towards the front of the space bar and just to the left of the touch pad assembly. Hold it down while it tries to go through the entire power up sequence.
Then let me know what happened.
Ron-
It will unexpectedly shut down with the error number 1073741819. NT Authority\system C\windows\system services exe
Try starting up in Safe Mode. When the computer turns on , immediately begin hitting F8 like mad until you get a screen where you can use the arrow keys to select how to start up. Use "Safe Mode" or "Safe Mode with Networking".
If you can boot up fine without the error, then you have a program installed which starts up along with Windows and crashes, causing Windows to shutdown. Check your installed programs, especially anything you might have removed/added right before this started happening.
If you can't start up in Safe Mode either, there may be something wrong with your Windows installation.
Mar 01, 2016 | Computers & Internet
Firefox is crashing
Firefox crashes can be caused by incompatible extensions or themes, issues with hardware acceleration and the drivers on your system, problems with your Firefox settings and other issues. If Mozilla Firefox is crashing every time you reopen it, you can troubleshoot Firefox with its safe mode, update the software on your system or create a new Firefox profile.
Safe Mode b> Mozilla Firefox includes a safe mode startup option. Firefox doesn't use extensions, themes, hardware acceleration or your custom settings when you start in safe mode. You can start Firefox in safe mode by pressing and holding the "Shift" key while clicking the "Firefox" shortcut. Click "Continue in Safe Mode" when the dialogue box appears. If Firefox doesn't crash when you start in safe mode, the problem is with your Firefox configuration. b> Reset Firefox b> If Firefox starts without crashing in safe mode, you can make some of the safe mode changes permanent. Close Firefox and restart it in safe mode again. Use the dialogue box that appears to select one of the options such as "Disable All Add-ons" or "Reset All User Preferences to Firefox Defaults" and click "Make Changes and Restart" to restart Firefox in normal mode with the changes. After restarting, you can re-enable extensions and themes one by one and install updated extensions that may fix the problem. Update b> If Firefox crashes safe mode, updating Firefox and other software on the system may fix the problem. You can download and install a new version of Firefox from Mozilla.com if it won't start. You should also update Windows from Windows Update, update any browser plug-ins such as Adobe Flash and update for your antivirus, firewall and other security programs. The crash may be fixed with newer versions of the software. b> Profiles b> Firefox stores your settings in a profile directory. It normally creates only one profile directory, but you can create an additional profile and start Firefox with that profile instead of using safe mode. Close Firefox if it's open, click "Start," type "Firefox.exe -ProfileManager" into the search box in the Start menu and press "Enter" to access the profile manager window. Click "Create Profile" to create a new profile, provide a name for the new profile and click "Start Firefox." Firefox opens with a fresh profile; you can start your old profile from the profile manager window.
b>
Jan 16, 2013 | Mozilla Firefox
Acer aspire 5736Z wont boot on any recovery options
Try starting up in Safe Mode (Console mode) and type in
"SFC /Scannow"Once its done you should be able to do recovery options.
If not, boot from the windows 7 recovery/install CD and choose "Repair".
Go through the recovery process using the CD and it should all be fine!
Dec 26, 2012 | Acer Aspire 5736z 4460 Laptop
Lenovo t440 crashes on startup
Turn on laptop then start tapping the F8 key continuously until you are given an option to start in SAFE MODE.
When you get to SAFE MODE you should be given an option to use SYSTEM RESTORE. From there restore your system back to a date when all was well with it.
Hope this helps
Jan 24, 2012 | IBM Lenovo ThinkPad T400 7417 Notebook
Unexpected crash down.
try to start the computer just after starting it start tapping F8 key then you'll get a menu which says safe mode, safe mode with networking, safe mode with command prompt.choose last known good configuration that will take your computer to the settings which you used previously.
Mar 17, 2011 | Microsoft Computers & Internet
Tried to install update and computer crashed
A few ways to try and eliminate.
Upon startup F8 for safe mode: Last Know Configuraton
Hit F8 for safe mode. Go into accessories>system tools>system restore
Doesn't work then: need Windows CD setup. Let it run and hit R for Recovery Console. At the DOS prompt type FIXMBR or FIXBOOT.
Mar 05, 2009 | IBM ThinkPad T30 2366 Notebook
Thinkpad T40 operating system failure/won't boot
Check your RAM, reseat them, if you have RAM in both slots, swap them around. If possibe test them in another computer.
Nov 29, 2008 | IBM ThinkPad T40 2373 Notebook
Noteboo t 40
What is it doing exactly, any lights, beep, does it show the initial IBM screen, what? What did it do just before this started, freeze, crash, noise?
Aug 13, 2008 | IBM ThinkPad T40 2373 Notebook
Ibm thinkpad t40
http://en.wikipedia.org/wiki/Blue_Screen_of_Death
http://support.microsoft.com/kb/174630
THe most popular windows issue in all the land.
Oct 24, 2007 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T20 2647 Notebook Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
