Question about RCA P52926 52" Rear Projection Television
Cannot operate tv manually or with remote
My tv has gone crazy!!!!. The picture shows excellent, but will not power on with power button. Remote does not work to tv at all. Can not change channels, volume or anything. I can access menu manually but it is hard to figure out, seems to be confused.
  • diva85 Dec 04, 2007
    Is this an expensive repair?
    Novelist:
    Champion:
  • 232 Answers
May have a corrupted eeprom which means you`ll have to call a tech, one thing you can try is;
Un-plug the tv`s AC power cord, wait 30 seconds, plug back in and pray, this will set re-set the micro to the default mode which may have gotten glitched by a power surge, hope it works for you.
Posted on Nov 30, 2007
  • Larry Eastman
    Larry Eastman Dec 04, 2007
    that really depends on where you live, costs more to keep a shop operating in say NYC vs St. Louis, doesn`t cost ya anything to call the local shops with your model number and symptom and ask them for a "ball-park figure", did you try un-plugging your tv for 30 seconds and then re-trying it ? do you have it hooked to a cable box or straight cable to the tv? Might want to try re-booting the box if you have one, same as tv, un-plug box for 30 seconds, plug back in and WAIT until clock re-appears on screen, good luck
SOURCE:
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
No channel set up
Hi, try pressing the "closed caption" button on the remote. I hope that works. If this doesn't work try getting your TV's SE-R0305 Operating manual and reading through it and it might be able to help you. You will be surprised at how much information is in the TVs manual.
Oct 07, 2012 | Toshiba SE-R0305 Remote Control
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
The tv was left on and gone off wit a red led showing under the clock on the front of the tv due too the remote being broken we dont know how to put the tv on
On the right side of the tv bazel frame have manual buttons,like a power button,like 2 channels buttons one for up and one for down and a Meneu button.Push the tv manual power button,ur tv should have power and tv will be on.Or try website like Remotes.com to buy a new remote same as ur original tv remote.
Dec 02, 2010 | Panasonic VIERA TH-37PX80B 37 in. Plasma...
The channel button on remote and tv wount work. it will not scan up or down. on either the remote or the tv
Did you check the batteries? If they're good, it might be broken, or you have the wrong remote.Try checking if its the VCR remote or the DVD player remote. If this doesn't help, then your remote has gone crazy.
Feb 23, 2010 | Polaroid Televison & Video
Cant get the remote to turn tv on off or channels
hmmm.. Do you have another remote that will operate that tv, try that remote and see if it will turn on and off the tv. IF you bought this new remote because your old one quit working it may be the tv and not the remote. If you have a camera phone you can check your old remote. Turn on your camera and aim the remote at your phone, look at the picture on the phone and press the power button on the remote, you shuld see the front of the remote flash, if you do then it is the tv causing your issue.
Sep 02, 2009 | Philips Magnavox 20MT133S 20" TV
How do you do a mackro for turning on several devices
The owner's manual give excellent instructions on how to do this.
You can find the owner's manual at the website for Universal Remote Control.
http://www.universalremote.com/downloads.php#professional
A basic overview:
  1. Enter macro setup mode.
  2. Select the button you want to put the macro on.
    You can save the macro on almost any of the main buttons or 400 "soft" buttons.
  3. Push the buttons you want to record (main-TV-power on-main-cable-power on-main-audio-power on-....etc.)
  4. when finished press the Light button on the side of the remote and Save.
Aug 18, 2009 | Universal Remote Control Osiris Complete...
RCA TruFlat 27F520T 27" TV Reset
Buy a new remote.
Look around the tv and find the menu button.
Generally there is a separate power button.
You can also download the manual:
http://tv.manualsonline.com/manuals/mfg/rca/27f520t.html
Dec 02, 2017 | RCA TruFlat 27F520T 27" TV
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. [email protected] I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
RCA P52926 52" Rear Projection Television Logo
43 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
