Question about Panasonic KX-TA62477 - 3 X 8 Expansion Card (KXTA62477) Expansion Module
Ta-624 Problem None of my KX-T7030 extensions are working. My fax line is able to get outside line by dialing 9 and then the telephone number. The same for my wireless Panasonic phone. I am guessing that the problem is the 62477 board. Any suggestions?
0 characters
1 Points
Hi, all of my KX-T7736 phones connected to KX-TA624 started to get lots of static noise and cannot receiveincoming calls> CO lines are clean. What should I check to fix the problem? Where can I get a...
psu problem the 7736 run a few more milliamps then normal as they have a larger display plus its powered all the time,and the psu cant cope....hope this helps
May 25, 2011 | Panasonic KX-TA62470-2 (KXTA624702)...
Two extension phones won't ring but all other functions work fine for our AVAYA system. These extensions are plugged in to our expansion module I suspect the module is defective and need instructions on...
Power the carrier off. Pollow the power cord on the right side of the 5 slot carried. There will be a pull switch or a rocker switch. turn off.
Once power out, remove bad module, there is a tab on the top OR bottom depending on the age of your carrier. Pull card away from wall, and insert new card.
Power system back up.
Oct 08, 2010 | Avaya Partner ACS 308EC (108463001)...
Panasonic KXTA 624, leds flashing,
I have the same problem.have you been able to diagnose and fix the problem?
Mar 16, 2009 | Panasonic KX-TA62470-2 (KXTA624702)...
Rosemount rs3 dcs,
A CTP Panel allows up to 8 comm lines (01-08) for an RS3 controller (A-H). Each controller then allows you to address jumper four FIMS per comm line (A-D) in a daisychain. Depending on which comm line you use and which address you have jumpered, will automatically define your FIM address and the addresses of the 16 points to be configured on your FIM.
I agree with Don, you need to know what you already have hanging from the controller. Type FS (FIC Status) to show what you have configured in all of the theoretical 32 FIM positions. Drop me an email if you need specific help, we are RS3 experts!
Optomation Systems is an independent software house, with over 20 years experience of the RS3 Distributed Control System. In addition to RS3 application software, Optomation also supports compatible products and solutions that provide independent migratory paths and life extension for the RS3 control system. This activity is not endorsed in any way by Emerson Process.
Aug 15, 2008 | I/O Cards
Message waiting another extension
which voice mail unit do you have need to know. If panasonic vm unit after dialing into your vmail box hit #6 then *and vm box number
May 19, 2008 | Panasonic KX-TA62470-2 (KXTA624702)...
Kxta624 problem with programming jack #01
I do not have any 824's in my network - I do know that on the 616 there is a set/program or run/program swith on the KSU that MUST be set to program before any work can be done on the first port
May 13, 2008 | Panasonic KX-TA62470-2 (KXTA624702)...
Panasonic KXTA624
Barry Decker,
I have the same system in my home and having problems with my phones as well... Didderent problems but problems... Do you know where you would call to get it serviced??
Thank you,
Brad Wilson
Mar 15, 2007 | Panasonic KX-TA62470-2 (KXTA624702)...
Panasonic KX-TA62477 - 3 X 8 Expansion Card (KXTA62477) Expansion Module Logo
Top Panasonic I/O Cards Experts
Martin Buck
Martin Buck
Josh Whitehead
Josh Whitehead
Are you a Panasonic I/O Card Expert? Answer questions, earn points and help others
