Question about Philips Magnavox TP3285C 32" TV
TV FIX I have this two year old Philips Magnavox TV. ModelTP3285CI. When I turn the TV ON horisintal line comes up on the screen and the TV shuts off a few seconds later. Can you suggest a repair. Thanks
  • PEZALOUM Nov 30, 2007
    It is not a single horozontal line. When the TV is turned on several diagonal lines(gray and white) come on the screen then the TV shuts itself off a few seconds later. Thanks
    President:
  • 1,284 Answers
A line across the screen means a loss of vertical sweep. This could be as simple as an IC or as difficult as a deflection yoke. These are not do it yourself repairs.
Posted on Nov 30, 2007
  • Don
    Don Nov 30, 2007
    I am still correct with the issue so an inappropriate rating is uncalled for.
    Thanks
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
My magnavox came on and shut off as fast as it came on have no power @ all
Well, if you are lucky a fan not turning correctly, otherwise the power supply or the lamp ballast has failed.
Dec 30, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnavox projection screen tv. The tv
Will you have got a lot of years on this unit. There could be a lot of things wrong here are some things to check.
SMD capacitor 2009 on Small Signal Board
Check fuse on SSB location 1003
Check resistor 3306 15 ohm surface mount
audio output IC 7700 on the Small Signal Module
May 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox big screen problem
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Aug 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 13MT143S
Hello.
I believe from your description that the vertical circuit has failed. either the IC or a capacitor. Sorry, but being only a 13" set I don`t recommend you repair it. unless you have a friend that would do it for you for the cost of the parts only.
Feb 26, 2008 | Philips Magnavox 13MT143S 13" TV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
White Screen w/ White Lines, Sound On, Turns off after 2 or 3 secs.
Hi If you mean thin white lines, this is is an indication of a problem in the Horizontal Drive ckt. most likely the Damper Diode has opened or shorted, this would cause the visual symptom and then the set would shut down, unfortunately this is a problem best left to a qualified technician to repair, hope this helps.
Apr 12, 2007 | Philips Magnavox 27MS343S 27" TV
Tv was on and shut off, sparks in back when replug in
The fact that you have smoke coming from the back is not a good sign if the quality of the picture was good before it failed its worth if you put in 150 to 200.Stay away from it and call a qualified technician for an estimate then you'll know.Good luck.
Sep 19, 2006 | Philips Magnavox TS3260C 32" TV
Philips Magnavox TP3285C 32" TV Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
