Question about Samsung SYNC SGH-A707 Cellular Phone
White screen every time i let the screen idle, when i press a button or open the phone or something, the screen is completely white  and i have to hit it to fix it, how do i permanently fix it???
  • 1 more comment
  • xWaRpeDx Dec 03, 2007
    The same thing recently happened to my A707! I haven't figured out how to fix it either I just have to keep smacking it :-/ As the day has gone on it has needed harder and harder hits to get it to return to normal
  • Ms Rubble Dec 18, 2007
    the lcd on my mp4 has also gone completely white! I can still use it but can't see where I'm navigating- I have to listen in the headphones to find out what mode it is in. Very frustrating! Any help?!?
  • Anonymous Jun 18, 2008
    need to open my phone cuz it blinks with the white screen i need to fix
This same thing happened to the screen of my Samsung Sync so I brought it to cingular and all they could do was replace it with a brand new one...according to them it's unfixable
Posted on Dec 24, 2007
SOURCE:
Lg g2 will not turn on
  1. Take your phone and turn it off - just press power button and select "power off".
  2. Wait while your device is shutting down.
  3. Then, press volume down button and power button together until the LG logo appears on the screen.
  4. When the LG logo is displayed, let go of the power button, keep pressing the volume down key and then press once more the power button.
  5. Once you do that, on your LG G2 the factory reset menu will be displayed.
  6. Press power button in order to agree and wait while the hard reset is being completed.
Jun 09, 2014 | LG G2 White for Verizon Wireless CePhone
My i2352Fh monitor has developed a white vertical line which tracks back and forth across the middle half of the screen how do i get rid of it? the screen is 3 months oldn
Thanks Melony - had exactly the same problem - your post above helped me fix it...... Here is how to fix it .
  • On the base of the screen press the Menu button (far right),
  • Then press < or > to get to the Extra (looks like a screwdriver and spanner) and press Menu again to Enter.
  • Press < or > until you have selected the RESET and press menu again to Enter.
The line should be gone. Close the menus and all should be fine. I hope this helps someone. I searched the internet and this was the only post that gave me a clue. Thanks again.
Dec 16, 2012 | AOC I2353FH 23" WIDE Monitor
My acer aspire one laptop screen is completely white how can i fix it
Power down the laptop (press and hold the power button).
Try turning it back on, and hitting the F8 key to get boot options. Start in "Safe Mode" or some other configuration that worked and see if that fixes the issue.
If the screen does not show anything at all, try connecting the laptop to an external monitor while starting up.
Apr 15, 2012 | Acer Aspire One PC Notebook
Phone locked, samsung sph-m580
I got this information from Sprint directly. I had your EXACT same problem. These are the directions they gave me and you may have to repeat the process several times before it works, but I guarntee it works!! Ok. turn off the phone, take out battery, replace battery, hold the U button on the keypad, then hold power till the phone turns on, then release u, then power, you should see the samsung symbol first and then if it works, it will go to a white screen, (try this as many times as it takes) Now, using the volume button on the side of the phone press down until you get to the wipe data factory reset, press enter on keypad, use volume again to select yes delete all user data by pressing down, hit enter again, let it work, hit enter again, and you're all set!! UNLOCKED COMPLETELY from that dreaded password that has locked you out, now enjoy your new phone!
Jan 10, 2012 | Cell Phones
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
I HAVE A HTC TOUCH DIAMOND. WHEN I TURN IT ON IT DOES NOT START UP IN PHONE MODE. THE SCREEN COMES UP WITH A RED,GREEN,BLUE AND WHITE BANDED SCREEN WITH DIAM130 64M SPL-1.38.0000 MICROP-DIAM (LED) V11 IN...
Looks like you should try to Hard Reset it.
This is done by having your HTC Diamond turned off first.
Then, hold the VOLUME UP and DOWN buttons at the same time and briefly press the POWER BUTTON.
Now keep holding down the VOLUME UP and DOWN buttons until you see a screen
At soon as you see this screen, you should release the VOLUME UP and DOWN buttons.
Now press the VOLUME UP button to complete the hard reset. Now this will completely format your HTC Touch Diamond as if it was turned on for the first time from the box. Everything once previously on the phone will be deleted including messages, contacts, music and the like. Hope I have been of assistance to you, Cheers :)
Apr 23, 2010 | HTC Touch Diamond Smartphone
Screen goes white and cant press the C or OK buttons
Yes you have to .The strip inside is a common problem on the samsung sliding phones
Jan 10, 2010 | Samsung SGH-J750 Cell Phone
IT SAY SIM LOCK AND ASKING THE CODE
This may not work on all Samsung phones!
THIS IS THE TEMP UNLOCK CODE FOR A SAMSUNG PHONE
Do this at your own risk:
Instructions
Press *#06# and write down your IMEI
Unlock Codes
Code 1: *2767*688 then your IMEI and then press #
For example *2767*688352708000828246# (Everything before the / for C225)
Code 2: *0141#
Code 3: 00000000 (8 zero's)
Entering the Codes
1. Switch your phone off. Remove the original SIM card 2. Insert another SIM card from an alternative network. Power up your phone. You should now see the "Wrong Card" message. 3. Type Code 1 into your phone, if this is entered correctly your
phone screen should now turn black and reboot itself. (C225 doesn't go
black but does reboot) 4. After the phone reboots the SIM card will be recognized and your
SIM will work. Be patient while your phone reboots and DO NOT press
any keys. At this point the phone is "Temporarily" unlocked.
5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
This should give you a message saying the phone is "Personalized". 6. Power off the phone and insert the original SIM, then power up. 7. At the SIM code prompt, it will ask you to enter a password. At
this stage enter Code 3. 8. After entering hit "OK" and your phone should complete initialization.
[/b]Instructions[/b]
Unlock Codes
Code 2: *0141#
Entering the Codes
any keys. At this point the phone is "Temporarily" unlocked. 5. Now at your idle screen type in Code 2 (*0141#) and hit the call button.
Your phone is now Permanently unlocked.
Another easy way is you put in a foreign sim put in the code *2767*2878# much easier and works just the same.
*2767*688 <your IMEI number>
Jan 09, 2010 | Samsung SGH-X820 Phone
My iphone froze i took a screen shot and the screen is completely white im still getting calls and text messages but i cant acess them i need help now!
Trying doing a hard reset on your iPhone:
1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
3. The iPhone should now shutdown automatically - (fade to black)
4. Turn the iPhone back on by hitting the sleep/wake button.
5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
6. You have completed a hard reset successfully.
Oct 20, 2009 | Apple iPhone 3G
KRZR K1 White screen
problem with flex cable(ribon).take it back to the shop
Sep 12, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung SYNC SGH-A707 Cellular Phone Logo
85 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
