Question about MPC Computers NEC AccuSync 70 17 in.CRT Conventional Monitor
Nec accusync 70 unfocus blurry
When i turn on my monitor everything is nice and sharp but when its 15 minutes pass it start to get blurry unfocus . What shall i do?
0 characters
1 Points
What is the fix to a TV - AccuSync PV46 that gets hot and turns off within about 5 or 10 mins.
open your monitor in on condition and see which component geting hot ok change component with new one and check it aain
May 19, 2012 | NEC AccuSync Computer Monitors
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
What flatscreen monitor is OK to substitute for sanpo alphascan 520?
Hi. Almost all the crt type monitors should work, it's flat screen monitors that seem to give computers problems with aspect ratios, and resolution settings.
I personally use an NEC AccuSync 70.
It might not be the newest monitor in the world, but the colors are crisp, clear, and bright.
And It allows a setting of 1024x768@85 hz refresh rate, which works great for my games.
As far as flat screens, I would probably go with an Acer, or a Dell monitor, as these two companies seem to have better quality from their monitors than most other manufacturers.
I hope this helps you out!
Mar 06, 2011 | Sampo AlphaScan 520 (White) 15 in.CRT...
How do I fix my screen from being blurry? I have an AccuSync LCD 72vw with AT&T services.
Hello: Try the following:
Signal cable should be completely attached to the computer.
Use the OSM Image Adjust controls to focus and adjust display by increasing or
decreasing the FINE control. When the display mode is changed, the OSM Image
Adjust settings may need to be readjusted.
Check the monitor and your display card with respect to compatibility
and recommended signal timings.
If your text is garbled, change the video mode to non-interlace and use 60Hz refresh rate.
Nov 19, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Help me please
Try this link, I am asumming you have the AccuSync LCD71VM monitor, I don't know what a n4 ibfgl is. But here is a link to nec that might help you...
Download the file NEC LCD MONITOR Installer.
Hope this helped you..THK
Nov 24, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
No picture; power LED blinking amber/green 2-2-2-2...
You can TRY to look for cold solder at the board esp popwer section.
Apr 24, 2008 | NEC AccuSync 120 (White) 21" CRT Monitor
NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
Jerry G.
Apr 24, 2008 | NEC-Mitsubishi Nec Display Solutions...
MPC Computers NEC AccuSync 70 17 in.CRT Conventional Monitor Logo
47 people viewed this question
Top MPC Computers Computer Monitors Experts
Gareth Cockram
Gareth Cockram
Barrett Palumbo
Barrett Palumbo
 Mike M
Mike M
Are you a MPC Computers Computer Monitor Expert? Answer questions, earn points and help others
