Question about Sony UP DR100 Thermal Photo Printer
Error message mecha trouble 0007...what does this mean?
Problem: The Printer does not detect the home position of the cutter during initialization.
Either there is a scrap piece of paper obstructing the path of the carriage that houses the cutter blade or there has been an impact on the lower side of the printer causing a bend in the metal that holds the home switch. This switch will trigger a sensor telling the printer that the cutter has reached the home position(right side)
Solution:Remove the paper scrap or Remove the door panel and check for damage on the right side of the cutter blade path and bend the metal piece to realign the switch so that the plastic carriage makes contact when reaching the right side.
Posted on Apr 02, 2008
2 Suggested Answers
SOURCE: sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Posted on Aug 11, 2009
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
Mecha error shows on the dashboard and goes off. Normally shows when the engine is first started in the morning.
I presume the "Mecha error" is in actuallity the "Check Engine" light? If so, the engine (powertrain) computer (PCM) would have stored a Diagnostic Trouble Code (DTC) in its memory. Find out what, if any, codes were recorded/stored in memory... we can take it from there.
Jun 10, 2011 | 2006 Hyundai Tucson
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Mecha error
it says there is a mechanical error meaning that there is an internal part no longer functioning yo need a radio
Aug 20, 2009 | 2009 Hyundai Sonata
DVL-V888 has MECHA CPU message
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Aug 29, 2008 | Pioneer DVL-V888 DVD Player
E-Mecha...what does it mean?
Hi
What brand and model! and can you specify the trouble you encountered!
Jun 22, 2008 | Nakamichi SoundSpace 5 Shelf System
Sony up-dr 100 error 0007
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Kvt 815 dvd error
Mecha Error is a Mechanical Error. You can try to do a reset on the unit but in most cases this does not fix the issue but is free to try and sometimes can suprisingly fix these issue. This is pretty much going mean that the unit will need serviced as it can mean the laser is mis-aligned or is no longer working or can even mean something in the mechanics of the unit is jamed. You can go to http://www.kenwoodusa.com/support/simple.aspx?men=1&M2=38&M3=78 to look up a service center or call 1-800-kenwood to have them give you a service center to send the unit to.
Nov 29, 2006 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
Sony UP DR100 Thermal Photo Printer Logo
254 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
