How to Perform the Hardware Test on a Lexmark Z840 and Z845 Color Jetprinter
Document ID:HO3002
Properties
Lexmark Z845How to perform the hardware test; Hardware test; Lexmark Z840 Color Jetprinter; Microsoft Windows 98; Microsoft Windows Me; Microsoft Windows 2000; Microsoft Windows Server 2003; Microsoft Windows XP Professional x64 Edition; Microsoft Windows XP
Solution
Performing the Hardware Test
Turn off the printer.
Press and hold the Paper Feed button.
While continuing to hold down the Paper Feed button, press the Power button ONCE.
When the Power button begins to flash rapidly, release the Paper Feed button. A test page will print.
That is because they cannot e refilled. The ones you get with your printer ( 28 & 29) are what Lexmark calls "return program cartridges", which means they are for one use only. I suggest you buy other cartridges that can be refilled. Those are either 28A or 34 (black cartridge) and 29A or 35 (color cartridge). Here is a link to Lexmark's site, where you can see the list of cartridges that are compatible with your printer. http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+Z845
st Solution
posted on Mar 13, 2008
eagle338 Rank: Wiz Rating: 79%, 740 votes
The
only work around to this is to use two catridges(2 color and 2 black
and white). The reason is the printer has a mechanism to check if the
same catridge is being used again. SO when you have two cartridges when
one is finished refill the other and use and vice-versa. This way you
will be able to refill and use for ever without any problems..
The only work around to this is to use two catridges(2 color and 2 black and white). The reason is the printer has a mechanism to check if the same catridge is being used again. SO when you have two cartridges when one is finished refill the other and use and vice-versa. This way you will be able to refill and use for ever without any problems..
I had the same problem with lexmark z845. It is easy to solve this problem.Just do like the picture I post and you never get the paper pull to one side again. The problem is the rolling motor is too strong, so it pull the paper out out the tray in oneside. I use the mini cassette box, stick it with the super glue. And the printer works very well
st Solution
The
Maybe your USB port or USB cable is not working? For sure you need to get the latest drivers for Vista, Try to download the driver from Lexmark website at http://downloads.lexmark.com/cgi-perl/downloads.cgi?category=Drivers&ccs=229:1:0:552:0:0&searchLang=en&os_group=Windows%20Vista
If that still doesn't work, see if you can get another USB device to connect to your computer - like a USB Flash Drive (or "thumb drive").
go to lexmark website and download millenium software driver. or just go to this link:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:552:0:0&emeaframe=&fileID=9031&searchLang=en&searchLang=en&os_group=Windows%20ME
