Ricoh FT2260 Copier
Could you please describe Error Code 71 on our Ricoh FT2260 copier, along with the most likely fix? Thanks.
  • neuanod Nov 30, 2007
    The code description does NOT pertain to the RICOH FT2260 copier. In layman's english, the paper is transported from the paper tray, passes under and through the toner assembly and stops against the paper pick-up roller before entering under the master unit of the machine. The pick-up roller is not turning to permit the paper to be transported through the remainder of its travel. That is what the Code 71 seems to be about. Thanks.
  • neuanod Dec 01, 2007
    There is no loose belt or worn gears. It seems that the gear assembly that is supposed to turn the "now still" paper transport roller is to be activated electrically by a solenoid. This isn't happening. Please try to get specific information that pertains to our machine. There is no apparent visible damage to any part of the paper transport system.
  • 1,006 Answers
There are basically two types of error codes:
  1. Errors that a developer can cause to happen. Examples include "Out of paper", "Not Reserved", etc. These types of errors are useful to developers and can be used to correct normal error conditions.
  2. Errors that are internal to the product. These errors should occur only if there is some catastrophic failure within ImageControls that is unexpected (see causes below). These types of errors are generally NOT caused by a developer. These types of errors are labeled as "Internal Error" in the trouble shooting tips below. However tech support and engineering can utilize these errors to find and correct problems.
These type of errors are often caused by the following conditions:
  1. product is not properly installed.
  2. peripheral not properly installed / connected.
  3. hardware problems in accelerator or peripheral.
  4. invalid image file data or file corrupted
  5. bug in ImageControls/Bedrock/Driver, etc.
The VirtualReScan error codes displayed below are accompanied by descriptions and troubleshooting suggestions.
Let me know if u got help?
Posted on Nov 30, 2007
  • 749 Answers
Try this website to refer to your error codes since the manufacturer of Ricoh uses one set of error codes for their machines. Click here
  • 1 more comment
  • Rommel Balcita Nov 30, 2007
    1-00 Original document jam.
    1-01 Original document too long.
    1-10 Document in ADF.
    1-17 Document exit jam.
    1-20 Fuser jam.
    1-21 Fuser jam.
    1-30 Out of paper.
    1-34 Out of paper.
    1-71 Cover open or cassette removed. "It maybe also a BAD switch, which is caused by the many times of closing and opening that area."
    (2-10 - 2-20) Modem errors. Bad FCU.
    (For codes: 2-13, 2-23, 2-24, turn power off and back on).
    2-50 Machine reset itself. Bad FCU.
    3-00 Replace G4 board or FCU.
    (3-10 - 3-30) Problems with other
    4-01 Line current problem. Could be
    FCU or NCU.
    4-02 Page longer than maximum.
    4-10 Communication error.
    5-00 Data reconstruction not possible.
    Bad FCU.
    5-10 DCR timer expired. Bad FCU.
    5-20 Memory inadequate.
    5-21 Memory overflow.
    5-22 Overflow after 2nd page scanned.
    5-23 Print data error.
    5-24 Memory overflow.
    5-25 SAF file error. Bad FCU or IC
    memory board.
    5-30 FCU or IC memory board.
    (6-00 - 6-99) ECM (error correction
    mode) or V.21 problems.
    9-07 Cassette feed jam.
    9-08 Jam.
    9-09 Fuser exit jam.
    9-10 Toner empty.
    9-12 Cover open.
    9-20-21 Laser diode failure.
    9-22-01 Fuser temperature too high.
    9-22-02 Fuser temperature too low.
    9-22-03 Fuser temperature too high in
    power save.
    9-22-04 Fuser temperature too high in
    power save.
    9-22-05 Fuser temperature too low in
    power save.
    9-22-07 Fuser temperature too low.
    9-22-08 Fuser temperature too high.
    9-22-09 Fuser thermistor failure.
    9-22-0A Fuser temperature too high in
    energy saver.
    9-22-0B Jumper 63 and 64 on FCU are
    9-23-31 Laser motor.
    9-23-32 Laser motor.
    9-29-51 HVT failure (bias).
    9-29-52 HVT failure (charge).
    9-29-53 HVT failure (transfer).
    9-29-54 HVT failure (mag roller).
    9-29-55 HVT failure (charge bias).
    9-29-56 HVT failure (transfer bias).
    9-29-57 HVT failure (developer and
    toner application bias).
    9-29-58 HVT failure (developer and
    9-29-59 HVT failure (transfer roller
    9-50 Optional cassette paper feed
    9-51 Optional cassette paper jam.
    9-60 Printer error.
    9-61 Memory overflow.
    9-82 Optional multi-purpose feeder
    9-83 Optional multi-purpose feeder
    paper too long.
    9-84 Cassette paper feed problem.
  • Rommel Balcita Dec 01, 2007
    So there maybe a loose belt in there or a worn-out gear especially that you mentioned that it is almost at its final stage, where the hottest part is located.
  • Rommel Balcita Dec 05, 2007
    Hoping that you tried re-inserting the connection of that solenoid. A mechanical switch must be located for the paper to activate that solenoid and maybe it's not working well... Worst case is, in the circuitry to activate that solenoid is already busted. Try to locate relays that triggers the switch
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer:
I do find the error code for a different Ricoh model (Aficio 1018).
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Error code PJ10 on Ricoh FW870
hi i have a ricoh fw870 copier cant fix it error code is 0j08 ,i need help in this
thank you
Dec 20, 2013 | Ricoh FW870 Black and White Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
P26 on screen. Cant clear it. Can you help - step by step please
In the Ricoh copier machines dont exist P26 error code.Please describe your problem and specify the copier models.
Oct 21, 2009 | Ricoh Aficio 1013F Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Error SC320 Ricoh Copier
Change the polygonal motor of the laser.
Apr 10, 2009 | Ricoh Aficio 1013F Copier
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Service code 591
toner supply motor lock. The toner recycle coil in the back of copier is clogged up.Major pain to fix but can be done
Apr 26, 2008 | Ricoh Aficio 1013 Copier
469 people viewed this question
