Question about Toshiba 55H70 55" Rear Projection Television
TV won't turn on
We hear a clicking noise, and the red light button to turn it on blinks...after unplugging it, it sometimes comes on, sometimes does not...help?
  • Dwain Dec 02, 2007
    when you plug the tv in. the power light blinks on and then off about three times. then still no picture.
    Novelist:
    Champion:
  • 232 Answers
The fact that it does come on and run properly "sometimes" means you have some broken solder connections inside your set, the board has to be removed and re-soldered and you`ll be good as new.
Posted on Nov 30, 2007
SOURCE:
My tv keeps saying stand bye and it won't cut on all its doing is making the click noise and the red light keep blinking
Try unplugging it for 30 seconds and see if it resets. If not, take the model # and get on the internet for the manual and go to trouble shooting page. It should answer your questions
Feb 13, 2013 | Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 17, 2008 | Toshiba 46H84 46" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
RCA Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. If you push the menu button after awhile the red light will stay on and not blink....
Model 32V434T Ch. #ATC010A will no come on. You can hear a click when it is turned and the red indicater light blinks. Eventually the red indicator light stays red. Tried unpluging set. Is it the EPROM ?
Jan 19, 2008 | Televison & Video
Toshiba 55H70 55" Rear Projection Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
