Question about Dell Precision M60 Notebook
Dell M60 LCD screen stopped working
All of a sudden, My Dell M60 lcd (WUXGA+) stopped working (3 days after warantee expired). I thought the laptop croaked, but I can output to an external monitor or use PCAnywhere and see the (virtual) desktop. Is the lcd blown? Could it be a loose internal cable connection
  • 59 Answers
Based on your troubleshooting, it certainly is the lcd that we are having problems with. It can be the cable or a back light problem. first try to reseat the cable. use this manual to guide you. http://support.dell.com/support/edocs/systems/wsM60/en/UG/index.htm
if it doesnt work, try to call dell. they have a grace period of 5-10 days from expiration date of warranty. if still no luck, call spareparts 800-3573355. purchase the lcd from there and install it yourself using the manual i gave.
hope this helps.
thanks.
Posted on Nov 30, 2007
SOURCE:
I have dell 1545 inspiron laptop. One day suddenly, the laptop's lcd screen shows colored vertical lines. I connected laptop to lcd tv and I could see desktop. I tried to enquire at various shops and
your LCD it toast its better to get it fixed. the cable only by-pass your lap top LCD thus allowint you to use your pc via another monitor sourse
Sep 27, 2014 | Dell Inspiron 15 1545 Notebook
I have Acer Laptop suddenly now the screen remains blank even after switching on the laptop. Actually as I was surfing the net suddenly the screen display color changed and later I thought there is...
if you can see the start up screen in full color when it starts then the last update could have caused it,
But its more likely that the plug inside the back of the LCD has come loose and needs to be replugged back in,
READ CAREFULLY FIRST BEFORE STARTING
Removing the screens bezels will void warantee
In Saying that ,
Heres how I would do a screen replacement,
You will need a small philips screwdriver for this ...
Remove the power and battery
To Remove the bezel from the front of the screen
There should be 4 or 6 screws holding the cover on,
Screws may be covered by rubber buttons,
then remove the screws holding the LCD to the hinges' frame.
Tilt forward your LCD and lie screen on your keyboard
LCD panels have a row of IC chips at the top that produce the images on your LCD so do not touch or flex this area because it may produce lines on the LCD or kill it completely.
botom of screen is inverter power and plug to screen
top rear of LCD is video feed from motherboard,
(above that are those important IC Chips-
DONT TOUCH THE CHIPS)
LCD wiil have tape fastening plug to the socket,
Remove tape and this will expose the plug.
Un plug from screens socket,
Reseat plug back into socket,
Put Tape back on to stop any unwanted movements,
Next step is to power up the LCD to test.
Rest LCD in back of lid and lie lid on table with base at 90 degrees for access to plug in AC power.
do not use battery for this test.
Turn ON power,
If it starts up, then you have a running machine again,
Shut down , unplug power and reassemble,
If LCD does not start then you need to replace the LCD panel and thats about all you can do,
Hope this helps.......
Cheers Misterdj
Apr 12, 2010 | Acer Aspire 4520-5582 Notebook
Multiple squiggly lines fill the LCD screen, after
Sounds to me like your inverter has gone bad. Typically it's situated just below your LCD. To get to it you will have to take out the screws around the LCD bezel. It's a long, skinny circuit board that the LCD plugs into. You can usually find a replacement on Ebay. Just be sure that you're ordering the correct part, otherwise it may not fit or work properly. I've also had times when the entire LCD was going bad and the display was full of squiggly lines. It's hard to say which one is the cause. I would try replacing the inverter first. That part is usually much cheaper than the LCD is.
Apr 10, 2010 | Toshiba Satellite M60 Notebook
Screen on Dell Inspiron 2200 went totally dark 2 months after warranty expired. Computer still works when I use cables and hook it to TV - but that is very inconvenient. Help?
that means the scren totally went down, there no way to fix, unless you send back to dell.
but there is a evsy way to use the bottom part that buy a extra LCD screen, so you can still using your laptop and display on the larger LCD screen
Dec 29, 2009 | Dell Inspiron 2200 PC Notebook
M60 battery will not hold charge plugged into AC adapter all day
if the battery is over 18 months old, the answer is replace the battery. If the battery is NEW then the charging circuit of the motherboard is bad
Sep 29, 2009 | Dell Precision M60 Notebook
Laptop New LCD Screen Cycling Colors
It's probably the wrong screen, cable ,or inverter; in spite of what the repair shop tells you .
Also, sometimes the cable gets pinched if not installed carefully, or the cable connector may need to be re-seated.
Is your laptop a Dell Precision M60 ? I'll see which screen it's supposed to have.
Jul 28, 2009 | Dell Precision M60 Notebook
Lcd screen black on laptop. External monitor works.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 31, 2009 | Dell Precision M60 Notebook
LCD Screen
Sounds like the new Samsung LCD screen is bad. The back-light on the Samsung LCD may be burned out. Check out this website; http://www.lcdsearch.com/
Mar 30, 2008 | Computers & Internet
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Dell Precision M60 Notebook Logo
264 people viewed this question
Ekse
Clive
Clive
