I have a sharp microwave. Stopped working. When I close the door and set a time the light comes on and the timer starts but thats it. No noise the turntable doesnt spin. No prior problems. No odd noises.
Comments:
Sep 02, 2009
- I opened the unit and found only 1 fuse. That was not it. It was a smallish less than 1/2 an inch long round white with silver metal ends. I do not recognize anything else as a fuse. Can you tell me where it is or what it looks like? Thanks B
I believe that there are to fuses inside this unit. One feeds the electronic components and the other feeds the turntable and the magnitron. Un plug the unit and check both fuses, you might get away with this cheaply. Please let me know if this helps. P.S. if one of the fuses continues to blow its time to get rid of the unit, because if they go bad they get stronger and very dangerous. What normally would boil water at 3 minutes could change to 45 seconds. Be careful.
integrated dishwasher 60cm
Only doing a very smal wash for about 2 mins then switching off as if...
(More)
Only doing a very smal wash for about 2 mins then switching off as if cycle finished.
Please help I have 22 for dinner tomorrow....
The light stays on when door is closed and cannot cook anything. Microwave thinks that door is still...
(More)
The light stays on when door is closed and cannot cook anything. Microwave thinks that door is still open!!
Light works and clock timer counts down but the base doesn't rotate and no heating or noise. any...
(More)
Light works and clock timer counts down but the base doesn't rotate and no heating or noise. any thoughts?
display frequently shows "e15" switching off and on at the mains clears the fault but it...
(More)
DISPLAY FREQUENTLY SHOWS "E15" SWITCHING OFF AND ON AT THE MAINS CLEARS THE FAULT BUT IT REAPPEARS AFTER ABOUT A FEW DAYS
