Question about RCA Lyra RD2763 MP3 Player
System file corrupted
When I turn on my mp3 player it says that the file system is corrupted what should I do? My player is the RD2763FMA Lyra. The suggested solution did not help. I did get the computer to recognize that something was hooked up, but Windows Media player does not. It went through the connecting, transferring and safe to disconnect screens, but then when I turned it off/on, it went to the File system corrupted again. I never did get any usable response from the thing. Oh, it did charge it up x
  • rodandbrooke Dec 03, 2007
    bounces between transferring and safe to disconnect. when i turn it back on says file system corrupted again.
  • 3 Answers
I actually fixed this!!! Mine had been giving me the "file system corrupted" error. So, I opened it up (unscrew the screw on the back, pry the back cover off with a small flat head screwdriver or a key, etc.) and saw that the connector between the CF drive and the motherboard had come apart.
I re-inserted the cable into the groove of the connector on the motherboard, pushed the broken/separated piece of plastic that serves as a retainer for the cable back down, held it in place, and taped it down with a 1/4 inch wide strip of duct tape (taped all the way around the connector/cable to help keep it in). I put the Lyra back together and then turned it on... and it WORKED! It came right on into the normal menu! Yay!
Good luck other people, I hope that this is the same thing that happened to your player and that you can also fix it! =)
Posted on Dec 20, 2007
Mp3 wont work
If the file system is corrupted, you have put files into the wrong folders.
To fix it, simply copy over all of your files from the mp3 player to your computer, format the mp3 player, then synch the files back onto it.
Oct 14, 2009 | RCA Lyra RD2763 MP3 Player
RCA 2763FMA quit working -file system corrupt
  1. Connect to your XP PC via USB
  2. Find the Jukebox drive in 'My Computer'
  3. Right click it and left click properties
  4. Goto the tools tab
  5. Error checking, click check now
  6. Tick both boxes then Start
  7. When finished checking close all windows
  8. Click 'safely remove hardware in the bottom right near the clock' (you need to do this every single time you remove the jukebox or your filesys may be corrupted again)
  9. Remove the USB lead from the jukebox and enjoy
Oct 25, 2007 | RCA Lyra RD2765 MP3 Player
Everytime i try to turn it on it says file system corrupted. It Does not go any farther then that.
Manual for Lyra RD2762 in pdf format:
http://www.voxxsupport.com/images/manuals/RD2762/media/RD2762_UMEN.pdf
Troubleshooting from page 53:
In case of a corrupted file system: player must be formatted.
FIRST BACKUP YOUR PLAYERS' DATA BEFORE FORMATING !
How to reformat the player is explained on this site:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/1529/kw/lyra%20format/p/158/r_id/103795
Home page on all support for RD2762:
http://support.rcaaudiovideo.com/manual.aspx?product=202
Sep 19, 2009 | RCA Lyra RD2762 MP3 Player
Just Format Ur MP3 Player it will work fine.........
Jan 17, 2009 | RCA Lyra RD2765 MP3 Player
Msg on player "file system corrupted"
Ribbin cable is loose inside from motherboard to hard drive. take it apart and slide it back in.
Sep 11, 2008 | RCA Lyra RD2762 MP3 Player
Please help me
wow, lyra is a piec a ****
Aug 16, 2008 | RCA Lyra RD2765 MP3 Player
NEED HELP
try uploading new firmware from the lyra website
also chech if there is a pinhole on back to reset,check manual first.problems with file systems can result if you have formatted the player as a drive instead of using the software that came with it,firware upgrade should sort it hope this helps andy
Jun 22, 2008 | RCA Lyra RD2765 MP3 Player
Question
how do u delete songs
Jan 14, 2008 | RCA Lyra RD2765 MP3 Player
Have you tried replacing your firmware? I believe the firmware for that model is here http://drivers.softpedia.com/get/FIRMWARE/Lyra/Lyra-Mp3-Player-RD2760-firmware-207.shtml but you may can get a newer version from rca's support site.
Nov 20, 2007 | RCA Lyra RD2762 MP3 Player
File system corrupt
I don't know exactly which model of the Thomson Lyra you have, but you can visit the Support page on their website, find your particular player model, and download software updates that might help solve this problem.
Nov 09, 2007 | Thomson PDP2812 (5 GB) MP3 Player
RCA Lyra RD2763 MP3 Player Logo
78 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
