Question about Dell E173FP 17" LCD Monitor
In power save mode
In dell system when i turn on the system then it says in power save mode press any key from keyboard and move mouse,when i press the nothing happens,system is not turning on
  • 4 more comments
  • Anonymous Dec 16, 2007
    power save mode
  • motocb500ul Dec 17, 2007
    The computer was in powersave mode, I moved the mouse and the screen flashed and the monitor went black. The monitor power button flashes green and will not come on anymore. What's wrong with it?
  • jiquita Sep 10, 2008
    used to turn on for a second, now i does not do it anymore.
  • Anonymous Nov 14, 2008
    When I turn on the compter the monitor will not start normally like it should, I had to manually tyurn it on just to get the message that it is on power save mode and to hit any key on keyboard or move mouse to start. I tried and followed the instructions and nothing happened, what should I do next?
  • Anonymous Nov 17, 2008
    My Dell monitor says it is in power save mode and that I should press a key or move my mouse to turn it on. When i do this nothing happens.
  • Anonymous Mar 24, 2014
    I want to turn off the power saving mode on my Dell V305 printer
Check that the cable has not come out of the back of your pc or monitor
Posted on Apr 17, 2009
  • 5 Answers
Try hitting the space bar on the keyboard. Does the mouse work normally?
Posted on Dec 06, 2007
2 Suggested Answers
  • 461 Answers
SOURCE: In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Posted on Nov 17, 2008
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    LX 300 Keyboard and Mouse: mouse works but keyboard doesn't...
    You can hit Window+U at the Welcome Screen, this will turn on the on-screen keyboard. Reinstalling the drivers should fix the problem
    Also to enter save mode, when the system powers up hold down F8 Key. Use your arrow keys to move to "Safe Mode" and press Enter key.
    Please post your feedback.
    May 18, 2010 | Logitech LX 300 Keyboard/Mouse
    How do I get my computer off power save mode?
    open control panel choose power options and you can turn it off
    Jan 12, 2010 | Dell E173FP 17" LCD Monitor
    My monitor shuts down after one second.
    Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
    1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
    2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
    3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
    4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
    Nov 13, 2009 | Dell Dimension 3100 PC Desktop
    Dell E173FP stuck in power save mode
    Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
    May 09, 2009 | Dell Dimension E520 PC Desktop
    In power save mode
    Nov 17, 2008 | Dell E173FP 17" LCD Monitor
    Just moved keyboard and mouse not responding.
    If you have wireless keyboard mouse try standard ones and see if they work you may get it off power mode
    Jul 31, 2008 | Dell Wireless Keyboard Optical Mouse w0147
    Dell E173FP 17" LCD Monitor Logo
    559 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
