Question about Brother MFC 420CN All-In-One InkJet Printer
USB Hello! My printer says that it cant detect my usb plug, but there is a plug in there and i have tried serveral other plugs and it still wont work
  • 832 Answers
SOURCE:
My printer wont install
May be the following can help.
1) plug the printer's usb to the pc.
2) make sure the printer is switched on.
3) insert the driver's cd of canon ip2700 printer
4) run the setup, wait for the installation to complete.
5) restart the pc.
6) pc will automatically detect the printer.
Feb 04, 2015 | HP Pavilion Computers & Internet
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
Jan 02, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
Its detected butit wont work
Printer has detected, its mean the printer is ok.
and the computer I think its ok too,
so the problem is the connection, usually this problem in the number USB port on setting properties with the number USB port on lap top that you have plug in.
May 29, 2011 | Canon Pixma MP500 All-In-One InkJet...
All my devices wok on the USB ports, but when I plug the Workcentre in it does not recognise the device
HELLO, SOME USB DEVICES DOES NOT NEED DRIVER AND AUTOMATICALLY DETECT BY COMPUTER BUT YOUR MACHINE NEEDS TO INSTALL THE CD DRIVER FOR THAT,
GOT THE CD THEN INSTALL..
Feb 25, 2011 | Xerox WorkCentre 4118 Network Kit...
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
My printer wont print out a letter i need. it says to check conections and make shure it is turned on but i tried it and it still wont work
You may have a problem with your communication connection.
1) Try plugging and unplugging your USB cord..
2) Go to "Control Panel/Printers".
3) Delete "Canon iP1800 series" printer.
4) Power ON printer, let computer detect printer.
If it will not detect and install the printer. There might be a problem with your USB cable.
Hope this helps.
Jan 25, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
USB connection does not work on SHARP AM 400
U need to make sure the USB cable is working. I've encounter a situation due to cable problem, when printing large file size copier hang...
Other than that, some OS require to install usb driver in order to detect the copier and install necessary driver...
Apr 06, 2009 | Office Equipment & Supplies
Trendnet TE100-P1U v2.0, USB light goes dark.
A couple of things I would try:
  • Start the Print Server, then insert the USB cable.
  • Plug in a self-powered USB port, and plug the printer cable into that. That could help if the print server is having trouble with the amount of power drawn by the printer.
Jan 28, 2018 | Trendware TRENDnet TE100-P1U Print Server
DP-1810P USB
sir/mam, there is no usb port on all 1810p and also the usb to parallel cable is not working with these machines.
what you can do as an option is to find a parallel print server, or you may connet the copier to the router with a builtin parallel print server
May 19, 2008 | Panasonic DP-1810P Laser Printer
Bluetooth
My MP500 has a normal flat USB plug in.  Turn off your printer and just try plugging in a normal USB cable into that slot...You can use the printer cable if you want. Haven't rec'd the BU20 yet, but don't think it will be a problem.
Oct 05, 2007 | Canon BU-20 (13803055436) Print Server
Brother MFC 420CN All-In-One InkJet Printer Logo
66 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
