Question about RCA F36650 36" TV
Rca 24V511T need vertical adjustmen at the top I already instal a new eprom ic
  • take123 Dec 25, 2007
    BMW Rider I know what you are talking about but the case is that the tv was working well respect to vertica talking before I chage the eprom and I know there are an adjusment methodo with parameter to give in the menu but how to acces that menu is the mater in the pass many time a go I did it but dont remember I know a lot of electronic and will understand If you give me instruccion, any way I will check all the cap in the vertical circuit and thanks a lot .........
  • spliceran Jan 20, 2008
    i need help to set up the eprom on my tv ?
    Novelist:
    Champion:
  • 232 Answers
Take123, problem is with vertical circuit not eprom, could be bad capacitor supporting the IC or the IC itself is bad, that type of problem needs a tech because once it`s fixed you will probably have to go into the service menu and re-adjust the vertical positioning, this of course will require the info in the service manual which you can`t easily obtain, questions? e-mail me back, BMW Rider
Posted on Dec 20, 2007
SOURCE:
Only bottom half of the screen is showing...
Resolder IC301=TDA8177 mounted on a heat sink. This integrated circuit has 7 pins.
Oct 19, 2014 | RCA 24V511T 24" TV
Rca 24v511t only bottom half is showing. Is this maybe a loose cinnection?
Vertical scan output section circuit fault. Contact any service technician. Your TV need a through checkup.
Oct 19, 2014 | Televison & Video
The screen is only showing the bottom half.
Hi. Look for cold solderjoints on the vertical output section. Most likely, the vertical final IC has bad solderings. Using a magnifier, one can see "craters" around the soldering pin/pad. Or just simply re-do all of them. Good luck;
Where is the dip switch located
dip switch is mainly located in computer mother board and ic circuit of tv
Feb 25, 2010 | RCA 24V511T 24" TV
The screen just shows a single line in the center from top to bot
vertical deflection failure. either solder on vertical ic, or bad capacitors in vertical circuit, and bad resistor &or ic failure. we fix these in home for 150.00 including 1-year warranty and trip. (oh plus tax for the next stimulus) mch
Mar 08, 2009 | RCA 36F530T 36" TV
RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Jan 30, 2009 | RCA 24V511T 24" TV
PARAMETERS FOR RCA
hold menue button in. push power once vol up once.vol up to76 ch to po1 po3  have fun.
Nov 13, 2008 | RCA 27V530T 27" TV
RCA 24V511T
I had this problem once before and it turned out to be the front keypad. Last time I tried to purchase one it was no longer available. Even when it was the wires going to it had to be reversed.
tv doctoor
Jun 08, 2008 | RCA 24V511T 24" TV
TV Repair Assistance needed
FLP stands for -- Front Lock Panel - I found it in a friends RCA TV manual. It is a lock you can place on the tv front panel buttons. When this is locked you can only use the remote. So once I knew that I went to RCA Service Center and ordered a new remote.. problem solved. So since your person couldn't even understand my problem, let alone solve it. I would like a refund please.
Thank you
May 30, 2008 | RCA 24V511T 24" TV
Vladimir reynoso
I have cable in stable on both tv. but the one tv doesn't get the cable to come in "
Mar 19, 2008 | RCA 24V511T 24" TV
RCA F36650 36" TV Logo
91 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
