Question about GE JE2160 Microwave Oven
Light Stays ON Inside - GE JE2160
We just bought a new in box GE Profile JE2160 Microwave today. When we plugged it up the light stays on all the time inside. Everything else works except for the light staying on.
  • Anonymous Jan 22, 2008
    just took mine out of the box as well
  • Anonymous Apr 06, 2008
    I too just bought a GE 2160 Microwave and the light stays on all the time. I'm thinking of just taking it back.
  • GE Master
  • 9,173 Answers
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
Because of pure design (GE never confirm it) you need to fix lever lock. By closing door this lock not working in parallel. One sitch closes earlier than another.
Posted on Dec 13, 2007
SOURCE:
I have a GE microwave. Beginning last night, the inside light stays on with the door open and when you close the door, the cooling fan starts up and the light stays on. The turntable doesn't rotate an
You have a major electrical issue within the microwave......potential electrical fire hazard. Unplug it and get a new one. Circuit boards are usually the same as the replacement price.
Nov 08, 2012 | Microwave Ovens
After I microwave the light stays on and the turn table stays turning whats wrong?
From the description the problem is in one of the door switches, usually caused by food partical build up, or ware. Each switch will need to be disconnected and tested.
Mar 07, 2012 | GE Profile Spacemaker II PEM31 Microwave...
Light wont turn off on GE profile
WHEN THE BULB BLEW IT PROBABLY BURNT OUT VIOLENTLY AND DAMAGED THE RELAY ON THE MAIN BOARD THAT CONTROLS IT. WILL PROBABLY HAVE TO REPLACE THE MAIN POWER BOARD WHERE THE RELAY FOR THE LAMP IS LOCATED
Mar 04, 2018 | GE JVM1790 Convection / Microwave Oven
I just bought a GE 1150 watt microwave. It worked fine in the store, but when we plugged it in at home, there is no power. The outlet works because I plugged a night light in and it lit up. Could the...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
May 07, 2011 | GE JE2160 Microwave Oven
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Inside Light stays on and the Start Button will not work at all!
You probably broke the door sensor switch.
The part must be tested before replacement.
Parts can be purchased from Partselect, Appliancespartspro, or Repairclinic. Have a look on google.
May 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light stays on Model #JE2160 Light will not go off.
there are two latches on your microwave door 1 for cutting power off to the magnatron and 1 for the light, it sounds to me like the 1 for the licht has broke off look on your door and check for break mark in line with the other lug. if not then the switch is broke inside the actual oven.
Mar 25, 2008 | Microwave Ovens
Light Stays ON Inside - JE2160
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
Please write back with your brand and model number if you need further help.
Nov 29, 2007 | GE JE1540 Microwave Oven
GE JE2160 Microwave Oven Logo
419 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
