Question about Frigidaire FEF355 Electric Kitchen Range
Frigidaire code F1
I turned on oven, set 400 degrees and heard a loud pop sound with the oven beeping with the code F1. Do you have any ideas? Thanks.
  • 1 more comment
  • Neon Rainbow Dec 08, 2007
    I replaced the Clock/Timer and the Clock Overlay and it works great. Thanks for the help.
  • rnichols45 Dec 23, 2008
    the oven stays on...my oven is about 5 years old...it's ele...is the clock area easy to replace...and where do you get it????
    Thanks, Jimmy Buffett
  • Anonymous Mar 30, 2014
    Shut breaker off and then turned back on, then the F1 Code was displayed
    President:
  • 878 Answers
Rainbow, F1 could be one of three things. The loud pop doesn't sound good. 1. Shorted keypad-replace the control. 2. The control sensed a runaway oven temp. In this case you would have to ohm out the temp probe. 3. The control itself may have a shorted relay-replace the control. The temp probe should ohm at approx 1100 ohms at room temp. Unplug the oven for one minute, if the code returns, first ohm the temp sensor (probe) if that checks ok, replace the control..Catriver
Posted on Nov 30, 2007
  • Ron Marek
    Ron Marek Dec 08, 2007
    That's great, can you change the rating to fixed...That will help me. Catriver
When I pushed the bake oven button on, I heard a loud pop! I thought a light bulb above my range (microwave oven bulb) blew out. Then F1 came on the range screen. We turned off the power to the range...
The F1 error code means one of two thing;either the touchpad is bad or a relay on the conrtol has shorted out. Well the loud pop and the F1,their is not doubt that a relay on the control has indeed shorted out. The fix for that is to replace teh control
PLEASE NOTE A SHORTED RELAY WILL MAKE THE HEAT ELEMENT TO STAY ON AT ALL TIMES AND THE BREAKER MUST BE LEFT TURNED OFF AT ALL TIMES UNTIL THE CONTROL HAS BEEN REPLACED OR IF LEFT ON THEIR WILL BE A VERY VERY GOOD CHANCE OF THE OVEN/HOUSE CATCHING FIRE
Aug 07, 2011 | Frigidaire Kitchen Ranges
I have a frigidaire range/stove. I was roasting dinner at 300 then turn the oven up to 400 near the end. Shortly after there was a pop that sounded like it came from inside the oven. I thought a potato...
F1
  • The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement. If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC). If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven. If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary. If the oven is actually overheating, replace the EOC. If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Read more: Frigidaire Oven Error Codes ' eHow.com http://www.ehow.com/list_7105089_frigidaire-oven-error-codes.html#ixzz1OVfekgRx
Jun 06, 2011 | Frigidaire Ovens
I had the oven on and I heard a loud popping noise, now the stove doesn't work (eg. the letter Fy1 comes up , the stove makes beeping noises, the stove door locks and unlocks etc.) The model # is...
rwere
Hello, and sorry to read about your problem.
Sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
Dec 24, 2010 | Frigidaire Ovens
F1 CODE ON FRIGIDAIRE STOVE
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Aug 15, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
Fault Code F1
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
Mar 25, 2008 | Frigidaire (FEB30S7D) Oven
Troubleshooting range
f1 code relates to a problem with the electronic oven control, no fixing the part only option is to replace it
Feb 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FEF355 Electric Kitchen Range Logo
1,498 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
