PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Trouble adding 2nd hard drive to hp dv9...
By retired Rich on Nov 30, 2007
Just less than 1 year ago I got a new laptop. It came with a 100gb sata hard drive and an expansion port for an additional hard drive. I bought an 80 gb sata hard drive, but the computer did not see it. After some research it was suggested that the 2nd drive needed to be the same size as the first one. So I got a 100 gb Fujitsu drive identical to the first one. But I have the same problem. It doesn't show up anywhere. I right clicked on my computer, selected manager, selected storage and disc management. At that point I should see the new disc, but it's not there. There must be something else that needs to be done but I don't know what. Thanks
Comments:
May 13, 2008
- Sata drives don't have a switch or jumpers like some drives to specify slave or master. I don't know if it's formatted. I figured I could format the drive when windows could see it.
Same Problem
Dec 21, 2008
-   Hi Igor_995. I have the same problem, HP dv9750, add new hdd HItachi 320gb 7200 (first 250gb 5400), I can't find jumper location. -   edward_il
Best Solution
posted on Dec 11, 2008
Very Helpful)
Igor_995
Rank: Apprentice
Rating: 100%, 8 votes
Summary after reading several threads on that and fixing this problem on my DV9010 + ST9500325AS:
The problem is known - modern drives featuring SATA II interface
(3 Gb/s) wont allow DV9000 to boot if the first drive is older SATA 1 (1.5 Gb/s). Though the machine does boot if the new drive is installed in the first bay.
The solution is to force the new drive to run only in 1.5 Gb/s mode
that is typically done with a jumper on the back side of the drive.
For Seagate Mementus drives the jumper location is shown here
http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #2
posted on Aug 05, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem, i took out my old one and put the new one on the drive 1 bay and i have it working, as soon as i put 2 drive, it freezes at put up... Took my original drive put it in another DV9000, did the same... any help?
Solution #3
posted on Nov 30, 2007
Somewhat Helpful)
Poohawk
Rank: Wiz
Rating: 84%, 256 votes
Hey, retired Rich! This is retired Ron!
Have a question. Is the new drive set up as slave or master?
Ron-
Was this helpful?
Yes
No
Solution #4
posted on May 13, 2008
Somewhat Helpful)
deccam
Rank: Apprentice
Rating: 70%, 5 votes
Has the drive been formatted? Windows won't see an unformatted drive, check the connections and make sure all is well there.
Was this helpful?
Yes
No
Solution #5
posted on Apr 04, 2009
Very Helpful)
bearvarine
Rank: Apprentice
Rating: 100%, 2 votes
I have an HP Pavilion DV9000 with two 120 GB hard drives factory installed.  I wanted to upgrade the secondary drive to a Samsung HM500LI 500 GB hard drive.  I installed the drive and the system eventually came up after 5 mins of some kind of internal existential struggle...  ;^)
After a few internet searches I learned that my new drive was SATA II and was somehow not being recognized by the system at all.  Samsungs website references the possibility of jumpering the drive to halve the throughput from 300 MB/sec to 150 MB/sec, but does not actually show how the jumpers are supposed to be placed.  Ultimately my solution was to jumper the device by trial and error, with this drive the jumper was correctly placed when it was connecting the outer-edge-most two of the 4 jumper pins.  Once the jumper was installed, the disk came up and was immediately recognized by the system.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #6
posted on Mar 18, 2009
Very Helpful)
PC Mac Tech
Rank: Apprentice
Rating: 100%, 5 votes
I have a dv9819wm that had the same issue in which I was runningidentical drives in both bays (to avoid any compatibility issues) - 2250Gb Seagate SATA II's. Here's a copy of a post I just placedelsewhere that will help you to resolve your issue PERMANENTLY, read on:
Something that I finally (After months of working on the problem of mysecondary drive not being seen, or worse, being seen for a short periodof time and then *POOF* disappearing from everywhere, BIOS Windows,everything! How FRUSTRATING!!!! And HPtech support sucks!! Sending it into them resolved nothing, they simplysaid it works and returned it to me. I work on computers for a livingand figured they were smoking something, to my dismay, I was right.
I finally found the cause in a whitepaper one day while researchingthis problem. The problem was that the second drive bay cannot utilizea drive running at 3 G/sec., it HAS TO BE clippedto 1.5 G/Sec. You can check with you drive manufacturer or simply lookat the top of the drive for a jumper setting, but you WILL need a smalljumper designed for laptop drives, others will not work safely. Once Iclipped the drive to the slower speed, it has been running like a champever since (at least the last three months or so). THANKS FOR NO HELPHP!!!!!! Why they would design a laptop that could use two drives andthen not give both interfaces the same connection speed is beyond me.
P.S.- The drives don't need to be the same size, but bigger is ALWAYS better in this case.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #7
posted on May 06, 2009
Not Rated)
alicekillia
Rank: Apprentice
Rating: 0%, 0 votes
i have a dv1010us and just put a fujitsu 250 gig in secondary. takes for ever to boot and dosnt see it anywhere. does anyone know where to put the jumper on a fujitsu?
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
how do i restore my aspire 5735-6694
Answer
Hi, I have an Asus 1000H Eee PC and when typing on it the cursor will "jump" either back... (More)
Answer
kk. i turned off my ibm think pad r51 aimmediatly and the next tim i opened it it said deletind... (More)
Answer
I have a DVD RW Drive: it's reading CDs but won't play DVD's. I have checked to update driver - not... (More)
Describe your PC Laptops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , IL
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
