Question about GE JE1540 Microwave Oven
Light Stays ON Inside - JE2160
I just bought a JE2160 GE Profile microwave today. When we plugged it in the light came on inside and it stays on. The microwave does work but the light will not go off.
  • GE Master
  • 9,173 Answers
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
SOURCE:
I have a GE microwave. Beginning last night, the inside light stays on with the door open and when you close the door, the cooling fan starts up and the light stays on. The turntable doesn't rotate an
You have a major electrical issue within the microwave......potential electrical fire hazard. Unplug it and get a new one. Circuit boards are usually the same as the replacement price.
Nov 08, 2012 | Microwave Ovens
I just bought a GE 1150 watt microwave. It worked fine in the store, but when we plugged it in at home, there is no power. The outlet works because I plugged a night light in and it lit up. Could the...
Hi, try the microwave in another outlet, if it works there then the first outlet is bad but if the microwave does not work in another outlet then the microwave is faulty and you need to take it back to the store and get another one as a replacement...
May 07, 2011 | GE JE2160 Microwave Oven
Hi, I choose the time, press Start but the light inside doesn't come on. The timer starts though. Any idea what could be the matter with it? Thank you!
It sounds like the internal lamp has gone. Replace the lamp.
Spares can be obtained from the manufacturers agents. Check out the manufacturers web site for details.
I hope this helps.
Nov 20, 2010 | GE JE2160 Microwave Oven
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
Change inside microwave light GE profile microwave
open the screw and then full out the side and top cover
Apr 21, 2010 | GE JNM1851SMSS Convection/Microwave Oven
JE2160WF02 was working, then shut off and will not power back on - circuit breaker OK
there is also a gfci plug in the kitchen that works like a breaker...find it and press reset.......there is also a fuse inside a microwave
Nov 17, 2009 | GE JE2160 Microwave Oven
Light insiude stays on
a door switch is not working properly. eric
Aug 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Inside Light stays on and the Start Button will not work at all!
You probably broke the door sensor switch.
The part must be tested before replacement.
Parts can be purchased from Partselect, Appliancespartspro, or Repairclinic. Have a look on google.
May 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light stays on Model #JE2160 Light will not go off.
there are two latches on your microwave door 1 for cutting power off to the magnatron and 1 for the light, it sounds to me like the 1 for the licht has broke off look on your door and check for break mark in line with the other lug. if not then the switch is broke inside the actual oven.
Mar 25, 2008 | Microwave Ovens
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
Please write back with more details if you need further help.
Nov 30, 2007 | GE JE2160 Microwave Oven
Microwave Ovens Logo
227 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
