Question about Texas Instruments TI-89 Calculator
Dropped my TI-89 and now it won't turn on.
I dropped my TI-89 from about 3ft only once and now it does not turn on.
  • 7 more comments
  • lonnie247 Jan 03, 2008
    Hi...I haven't used my Ti-89 in about a year...I put new memory battery and 4 new AAA batteries and it won't turn on. No dropping or any other abuse has be done to it. Please help!!
  • x8o8x Jan 07, 2008
    Just pulled my TI-89 out today after a couple of years, frantically replaced the AAA's and the cr-1616 (watch battery) to no avail. Will not turn on. Changing the display brightness/contrast does nothing.
  • leye Jan 30, 2008
    I had not used my calculator for more than a year and it does not turn on even though i replaced the AAA and the backup batteries please help!!!!
  • SHARIQNAQVI Jan 30, 2008
    my ti 89 has not been used to much in the past 6 months and no it will seldomly turn on.
  • rgmbarton Feb 25, 2008
    Dropped my TI 89 once and now it won't respond at all. Have tried replacing the batteries and changing the display.
  • Anonymous May 28, 2008
    not tried anything yet
  • Anonymous Aug 26, 2008
    I didn't use mine over the summer and it won't turn on, i know it is not the batteries tho!
  • bopbippity Jan 19, 2009
    Didn't start Ti-89 for 6 months and it will not turn on now.
  • Anonymous May 23, 2009
    I didn't turn my calculator on for about 2 years and even after changing batteries, nothing happens.
  • 16 Answers
3ft is quite high. Something may be broken. Send it to your retailer for servicing
Posted on Jul 09, 2008
SOURCE:
I dropped my calculator on the floor and now it won't turn on
Sometimes a whack on the head helps, I mean device. But no guaranty.
Mar 18, 2015 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
I have a ti-83 plus and i had it since the 9th grade. I am now in the 12th and it suddenly stopped working...it wont come on. what should i do
Your solar cell battery may have malfunctioned or if your system experienced shock, i.e being dropped suddenly then that could also compromise is internal components. Check your batteries, if not You may need to replace the unit
Nov 13, 2009 | Texas Instruments TI-89 Calculator
Ti 89 detected but couldn't get status
Here is what the FAQ and Knowledge Base area of the TI site has to say about the problem you are having. Hope it helps.
How do I correct the error message "TI-83 Plus or TI-89 detected, but could not get status" using the TI Connect software for Windows®?
The Operating System (OS) will need to be updated on the TI-83 Plus family or TI-89 calculator in order for the TI Connect software to detect the status. Try the following procedure to install the OS from the TI-83 Plus and TI-89 Boot Screen. Make sure TI Connect 1.6 is installed on the PC.
If using a TI-89 calculator:
• Connect the TI Connectivity cable to the TI-89 calculator and the computer.
• Do not start the TI Connect software.
• Download the TI-89 v2.09 OS onto the PC's desktop.
**Force the TI-89 into the "Boot screen" (see instructions below)**
• "Press I to install..." (press the [9] key).
• Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
• Follow the on-screen directions to install OS version 2.09.
The download should begin.
**Steps for Boot Screen:**
• Take one AAA battery out, press and hold down the [APPS] key while reinserting the battery to force device into the Boot Code screen.
• "Press I to install..." will appear.
Once the OS has completed installation, the TI Connect software will be able to detect the TI-89.
Oct 31, 2009 | Texas Instruments TI-89 Calculator
My ti-89 will not come on
Check to be sure the battery contacts are actually touching the batteries. You might try bending them in toward the batteries (or stretching the spring a bit (if they are that kind of contact - I can't remember). Also be sure you are using good replacement batteries (sounds silly I know, but sometimes you get a dud).
If it still doesn't come on you might want to try opening it up and looking inside (can't hurt - it's not working anyway, right?). Sometimes, because of a drop, a part might have come loose and can be resoldered or there might be some other visible problem. (My daughter's TI-83 had a little coil that had broken loose after she dropped it, and it was a simple repair.)
Dec 11, 2008 | Texas Instruments TI-89 Calculator
TI 89 Titanium
Well the best solution is to stop making more problems
Oct 26, 2007 | Texas Instruments TI-89 Calculator
Half of screen blank
it may have been spoilt, TI-89 Titanium calculators are not very lasting. You may want to try the resetting all memory (2nd 6 F1 3 Enter)
Oct 17, 2007 | Texas Instruments TI-89 Calculator
Screen Solid Balck
Hey, if this is a ti-89, press green diamond button, then -, keep going and it soguld fix itself
Sep 01, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
2,332 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
