Printer scans and copies but won't print. Says offline. Could I have a bad USB cable? Haven't tried that yet.
Comments:
Aug 13, 2009
- Thanks for the quick reply. Printer was online but did not print. Got "Error-Printing" in print queue. Will try a new/different USB cable. Otherwise, the printer internal interface is bad (I assume).
Aug 14, 2009
- Thanks.Already tried that as well. No luck. I'm borrowing a new USB cable this weekend.
Aug 15, 2009
- New USB cable did not help. Must be bad printer interface.
Aug 15, 2009
- Yes, I tried reinstalling newest version of the driver - no help. One last resort is that I will try it from a different computer.
Aug 22, 2009
- Fixed the problem. Had to delete the printer in
Windows and add it back again. Working fine now.
Is it showing offline on computer or on the display of printer? Try this: go to printers and Faxes in Control Panel, right click on your printer and select the option Use Printer Online. Now check, in case it is already online from there then you need to get the USB cable replaced,
Please rate this solution so that we can help you and other people like you.
Comments:
Aug 13, 2009
- You may also try reinstalling the printer drivers also before buying a new cable.
Aug 15, 2009
- Did you try reinstalling the drivers as well?
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
Good clear troubleshooing procedure
" - klezwoolfe
hi, CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
Printer errror has occured. Turn off pwr then back on. Shows 6AOO at top. have tried over and over...
(More)
Printer errror has occured. Turn off pwr then back on. Shows 6AOO at top. have tried over and over pulling plug and reconnecting. Whats my problem??? John K jtksr@yahoo.com
