Question about Brother MFC-3240C All-In-One InkJet Printer
Top Paper Feed Won't Work
Top feeder doesn't work. The rollers turn but I have to force the paper into the roller for it to catch & start copy/fax/scan.
  • 1 more comment
  • lazuc Dec 08, 2007
    When i want to print something it say no paper feed , to reload paper and press start, ive done it over 10 times and still the same error.
    I have also turn it on and off and still nothing just the beeping sound and no paper feed message again.
  • Anonymous Jan 12, 2008
    I have almost the same problem. Regular printer paper is not a problem but my Brother MFC alll in one will Not take any other thickness of paper/ As I create photocards, documents with photos and just plain prints that are then impossible alltho I keep trying, like an idiot, it will grind and grind, then come those beep-beep-beeps. WHY will this printer not print on any other paper besides typing paper thin sheets? If I didn't have so much expensive ink stored up, I'd throw it out the window! pb
  • mark24317 Jan 22, 2008
    Hi, I have the same problem and have cleaned the roller feeds. It seems like the paper hits a hard stop like in a regular printer when loading it into the ADF and I can't even push it into the rollers. You can hear the grinding and see the rollers at the front near the output moving but the paper will not feed in from the top (ADF). Help!!
    Scholar:
  • 43 Answers
Like a worn running shoes, the paper feed roller of the Automatic Document Feeder (ADF) have lost it's traction and has to be replaced or cleaned. Paper just slids and doesn't picked up properly without that little push. Professional servicers use a cleaner specifically designed for rubber rollers. However, YOU CAN get extra miles on it by dabbing a Q-tip in warm water and cleaning the paper feed roller on the ADF. Like all eletrical devices, the unit has to be turned off and unplugged before working on it. Take all precationary measures and goodluck.
Posted on Jan 17, 2008
SOURCE:
I have a minolta copier (Di1610fp). The feeder does not work. When a paper goes through half, it stops
Try cleaning the media rollers with 409 solution. The media feed rollers become dirty after a certain amount of prints. The toner is a wax based toner so excess wax gets on them after a while. Dirty media feed rollers can also cause image shifting problems. I hope this helps you.
Apr 15, 2011 | Konica Minolta Minolta DI1610P Printer,...
Hp deskjet 6122 paper feed
Try putting Isopropyl alcohol on the feed rollers. These rollers become hard and smooth with time and cause all sorts of paper feed problems. You can find isopropyl alcohol at any drug store(it is rubbing alcohol).
Aug 10, 2009 | HP DeskJet 6122 InkJet Printer
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
PAPER FEED DOESNT WORK KONICA MINOLTA COLOR PRINTER
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Stuck paper in printer
the only solution for this is to dig it out
remove the paper feed cartridge, open the printer up and remove all corona wires, and anything that will slide out
look to see the feed rollers and try lifting on the rollers with your fingers to take any tension off of the top roller always try to remove the paper from the feed area slowly work the paper out if you still see small piece of paper try working them out with a stiff piece of index stock
avoid damaging the rubber rollers with a sharp object and by all means do not force the feed rollers they were designed to move in one direction..towards the copy area a pair of tweezers and hemostats work very well
the fact that the paper went in sideways lends me to believe you have a fed roller problem or an obstruction
once you clear the jam cean the feed rollers with soft cloth and alcohol
good luck
Dec 03, 2008 | Brother HL 1440 Laser Printer
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Oct 28, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Paper in 3310 HP
You have a possible paper jam or foreign matter in your roller area or feeder area, get a torch and thoroughly check inside unit, near carriages, roller and paper feeder.
Aug 17, 2007 | HP Photosmart 3310 Printer
Brother MFC-3240C All-In-One InkJet Printer Logo
314 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
