Question about Electrograph Systems DTS42W 42 in. HD-Ready Plasma Television
Non working TV, can someone help???
I have acquired a Plasma tv model DTS42W that is not working. When you
turn on the power using the back button there is a click which may be
normal and the green light in the front comes on. Being that the tv is
not in warranty I removed the back cover and checked all of the fuses
which were fine. When looking at the back when I power it on I notice
two green led's that lights up 8003 light s up and stays lit and 8002
lights up with the click but goes out with another click. At about the
same time a red led (8004) lights up. this is all that happens.
Nothing flickers on the screen at all. All of these led's are located on
the power supply board LJ44-00025A. I believe this tv is the same as the Gateway GTW-P42M203.
What advise could you give as to what the problem might be with this tv
and how I can go about getting parts for it?
Thanks,
Scott
  • 1 more comment
  • bwhocutt Jan 01, 2008
    I am having the same problem with my SAMPO 42". Did you ever find the cause? Is it as simple as a power module swap (the LJ44-00025A board)?
  • Zippo0526 Feb 15, 2008
    It is, I found a power board and it worked as far as power but I still have no video. I think my video board is fried as well. You can email me to discuss further, I may be willing to part with the power board or any other parts. [email protected]
  • Cedric Hamilton Mar 14, 2009
    I have an issue with this TV also. I have a Phillips TV 42 inch 42PF9431D. It does not power on and all the fuses check out okay except the F8001 is missing on the LJ44-00119A which I believe is the power board. How many boards should be inside this TV? I have 1 large one on the right with a bunch of ribbon cables coming out of it and another one on the left a little smaller with 2 ribbone cables coming out of it and then a few smaller boards. I have the power board out right now but do not see any issues with capacitors at least visually. Does anyone know where I could find the fuse that I need for this board?
    Thanks,
    Ced
    Problem Solver:
  • 11 Answers
Replace Q8023 (top224y) which you will find is blown apart or it's shorted, and the Q1 (2sk2662) which would check to be shorted inside the heat shrinked wrapped board next to the blue relay and the smd zener diode ZD8018 (shorted) along with the ceramic fuse F8001.
I don't remember the value for the zener diode but there's lots of them with the same color code. You will have to take one of the others off to test on a resistor jig to get it's value.
The 2SK2662 is a cross for the original.
Posted on Apr 29, 2008
  • dino066 Sep 23, 2011
    I have exactly the same problem, although my TV is a Gateway GTW-P42M203, the parts are the same. There are 2 boards on the left side of the TV (looking from the back). I don't know too much about electronics but there are like 3 chips on each board. In one board, the chip IC5404 and on the other board, the chip IC5401 are burned. And each time that you try to turn the TV on, the alarm led (8004) lights up and the chips burn a little bit more.
SOURCE:
I have an element 42" plasma, we were watching a
staceydesjar
Try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After this, you should get your picture back. I hope this helps.
Ray Calo
DISH Network
Dec 30, 2010 | Element Electronics PLX4202B 42 in. Plasma...
TV was on. Now it is off and will not turn back
more than likely blew a fuse on the power supply take the back off and check the fuses with voltmeter
May 20, 2010 | Samsung 50 in. Plasma TV
Hi, I have a DTS42W Electrograph that turns on but no image coming on but i can see the on screen menu perfectly, help please!!!
check the cables going to your unit, if the graphics are ok the tv is ok, hast to be a bad connection.
Dec 10, 2009 | Electrograph Systems DTS42W 42 in....
Broken plasma screen
You need your Tv product code wich is located in the back of the TV next to the serial number.
you can get one directly from LG ($500-$800) or you can try EBAY, look for a TV non working with a good panel, it doesn´t matter why is not working as long as the panel is in good condition, the price range is wide but you can get one for $150-$250.
And no you can not use any 42" plasma.
May 16, 2009 | LG 42PC5D Television
LG 42pc3d plasma broken screen
Wow, that sucks. I hope you catch those guys.
Your part number for the plasma display panel is 6348Q-E128N.
Partstore.com is the only place that I can find a replacement plasma panel. The cheapest they have is $1,045.95. :(
Shopjimmy.com sell replacement panels too, but they don't have one in stock for our TV right now. Their priced about $300
The only thing I can suggest is to find someone locally that is selling the model TV, but non-working with the plasma panel not damaged. Then use the panel off that TV.
Sorry I couldn't help you out more.
Please rate me based off the info I provided.
Mar 09, 2009 | LG 42PC3D 42 in. Plasma Television
Dts42w will not turn on ? i see a red light in back of set on
what kine of additional plug i need to plug in i am having problem learn how to trouble shooting the power in the tv also i am having problem with the tv tube i am trying to learn how to do these thing so that can help myself and my letter son i have no money ta this time is there anyway that you all can help me thank you
Dec 18, 2008 | Electrograph Systems DTS42W 42 in....
Power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
Jul 25, 2008 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Electrograph Systems DTS42W 42 in. HD-Ready Plasma Television Logo
1,257 people viewed this question
Top Electrograph Systems Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
David Bukovaz
Are you an Electrograph Systems Televison and Video Expert? Answer questions, earn points and help others
