Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi vs-5041 picture intermittently goes off
My big screen's picture will be normal, then some lines will appear horizontal in random sequence for a second or so then picture goes off on all inputs. It may reappear for minutes, hours,???. The dvd input will light up blue. the picture may work for hours or days, but becoming worse at going off. I have a masters electrician license, but I am not a tv repairman. Can anyone help?
  • 1 more comment
  • catTracker Dec 15, 2007
    I don't know where the convergance ic is located. I have had the front and back off. Cleaned and checked connections.If you bump the front panel at the display light (next to the power button the picture will come back momentarily. I have checked all the connections to front panel. The problem has gotten worse. Picture will come on every time you turn the tv on then go to horizontal lines running in all kinds of directions then go dark.
  • catTracker Dec 16, 2007
    Yes, I've soldered many times. I'll look at it again and try and locate the convergence ICs. Do you know how many there are?... just one? I'll check all boards for bad solder joints. Thanks for your help!
  • clindell Nov 17, 2008
    i can kick the bottomand the picture will come back for a while like something is loose
  • 4,402 Answers
My guess is convergance ic but to troubleshoot it the best soultion might be to get a can of freeze and spay it on the IC while the problem is happening and or tap the board/ic's to see if you have a loose connection,
Posted on Dec 14, 2007
  • Cary Farah
    Cary Farah Dec 15, 2007
    sounds like you have a loose connection then, are you any good with soldering? or know anyone that is?
    the convergence ic's have a stk392??? on them, best thing to do is keep the unit off til it's fixed
    check the underside of the board and check for bad solder joints or discolored solder, i would touch up all of the connections on the convergence ic for sure
    if you dont know how do it you can send it to
    becarefull theres high voltage in that there box.
  • Cary Farah
    Cary Farah Dec 17, 2007
    there is at least 2 on some set there are three, it has a large heat sink (silver in color) attached to it
Blurry mitsubishi projection VS 5041
there a one or more defective tube needs to be replaced is typical efect when is tube end of life.
Jan 02, 2010 | Televison & Video
Mitsubishi vs-5041 -after a few hours on, the tv goes black
Get the projection bulb checked if fine its something internal in your tv but i think you need new bulb
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Rainbow line will come across screen and then goes blank. This is an intermittent problem. Normally if I turn it off and back on, it works. Now it does not.
try resoldering the vertical output IC, the IC runs at a hot temperature and this can cause the Pins to have cracked solder.
May 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi big screen won't stay on!
Its very possible you have a failing resistor r2200
Nov 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi #VS-45605
We had a blue cone on the screen. We have adjusted the sharpness, contrast, and cross hairs. The cone has almost completely disappeared, but we still have blue shadows. Could this mean a blown color tube?
Any suggestions would be greatly appreciated.
Aug 13, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitusbushi VS-4544 Horizontal lines then looses picture.
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Jul 14, 2008 | Mitsubishi VS-4544 45" TV
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
