Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Have a 32 sony trinitron
Picture comes in good but will flash black an the to picture back and forth
  • 1 more comment
  • manager1 Dec 04, 2007
    model kv35s40
    itis a 35 inch i think
  • Anonymous Apr 20, 2008
    yes i just got the same issue with mySony Trinitron Wega tv its a 30" though or 32" . could you get it fixed.
    President:
  • 1,284 Answers
Can you give me a model of the TV. It will be KV32?????
Posted on Nov 30, 2007
SOURCE:
Kv-25x5u picture goes off but sound still there, red light at front flashes 4 times every 5 secs, picture comes back on after 15 mins
if you are a tech the set is having problem in the vertical and horizontal circcuit...check IC 1509 and Q1505.good luck.
Sep 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron 32" tv. When I turn it on, it has started taking longer and longer for the picture to come on. Sound is fine. Now once the tv is on for a while, the picture goes black for...
Yes.... u must adjust the screen voltage going to picture tube....located on the CRT module>>>little board connected directly to picture tube (take back off TV and you will see ) play around with screen control on the CRT module......can be adjusted at times to keep from losing picture!!! tube is bad...i know sure looks good when showing a picture....TRY adjusting screen voltage ( YES while TV is ON>>>CAREFULL ) gl
May 19, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony 32" xbr trinitron trusurround T V picture is black
Most likely on a trinitron tube if it is dark is the high voltage capacitor has blown. This is the device that feed the 30,000 or so volts to charge the tube, it attaches at the back with a clip and ****** and a single cable coming from it.
You can check easily if it is definately that as you will notice if you power the tv on and off once or twice if you get that static charge feel from the screen, if there is none there then almost certainly that is the problem.
Mar 10, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron Blinking
Hi R012611H
Sorry to take so long to get to you. Most sony Tuve TV's are pretty good performers for colour. If you are into that sort of thing, so can be worthwhile fixing. If it has power supply problems, may cost you up to $200 to fix. Rule of thumb, if repairs are more than half the replacement cost, it is uneconomic to repair.
regards
robotek
Jun 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen went BLACK!
My Sony FD Trinitron TV did samething, started flashing, then eventually went completely black with volume. I got on internet searched found a solution, i tried it, it worked. unplug tv, remove all screws, remove back. towards bottom right theres a transmitter with a couple of knobs, we plugged tv in and moved knobs around and it worked. Also was extremally dusty, we used computer duster for a better connection. hope it helps you
Jan 26, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
