Question about Honeywell HZ519 Baseboard Heater
Stopped working? Heater stopped working?
  • 83 Answers
Check for lint inside and on the edges, it may have blown and you need somebody to repair this, is it smoking at all?
Posted on Nov 29, 2007
SOURCE:
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed ' http://www.atlasappliances.com
Aug 19, 2014 | Kitchen Ranges
Fiat weekend elx heater stopped working
most likely you blew a fuse for the heater
Jul 18, 2014 | Vehicle Parts & Accessories
Honda pilot heater stopped wprking after battery replaced
I would agree with Honda. Why would replacing a battery ruin a heater?
Mar 26, 2014 | 2006 Honda Pilot
Probs the hearer tap, or the cable that turns the heater tap might be broken, usually a landcruiser has gr8 cooling and heating
Jan 05, 2014 | Cars & Trucks
Wall heater stopped working pilot won't relight
Are you out of gas? If it was running and just stopped and the pilot won't light when your pushing the pilot knob, you may have ran out of gas
Dec 06, 2013 | Rinnai Toyostove Direct Vent Heater: Laser...
2005 mazda 3 heater has stopped working
does the blower motor run? Is it that you get no heat? check a few things. does both the heater core hoses get hot.? and it can also be a blend door motor
Dec 15, 2012 | 2005 Mazda 3
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
2000 ford windstar 3.8L Front heater has
what stopped? the air doesnt blow,if thats the case then replace the blowermotor resistor, its located on heater box on passengerside next to blower motor.hope this helps, let me know if this was the problem.
Dec 24, 2009 | 2000 Ford Windstar
Honeywell HZ519 Baseboard Heater Logo
285 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
