Question about Linksys WRT54GL Wireless-G 54Mbps Broadband Router w/Linux all-in-one Internet-sharing Router With 4... (WRT54GV4)
WEP key How can I find my WEP key? My new lap top is asking for it.
  • 83 Answers
Really depends on your router, if it is linksys (Most common) it's simple.
Connect a computer to a wired connection on the router. Point your browser at http://192.168.1.1/ That should take you to the admin interface of the router. If that doesn't work, check the documentation that came with your router --- it will give you the correct aaa.bbb.ccc.ddd IP address.
If you (or someone else) has not set the password for the admin screen, the default for Linksys (the last I used one) was blank for the username and "admin" for the password, but again, RTFM. BTW, of you set up WEP security but left the admin login default, perhaps someone found your wireless and changed the key for you.
If all else fails, do a hard reset on the router and start over. "Hard reset" is not just a power cycle... there is usually reset button on the bottom or somewhere that requires a stylus (pen, paperclip, etc.) to push it... you usually have to hold it in for 30 seconds or more to cause the hard reset. This will take your router back to factory default settings for everything.
But if the admin pass / name is incorrect try
Account: Admin
Password: Password
Or
Account: Admin
Password: Password
try both with capital start, then all lower case, Hope this helped!
Posted on Nov 29, 2007
  • 17 Answers
SOURCE: can't find wep key
With each new router comes a new WEP KEY by default this could be found normally on the back of the router/access point near the bar code it should have something like this:
SSID: XXXXXXXX WEP KEY: XXXXXXX
If you don't find this sticker or don't have it just reset the router or connect by cable go to the web interface and copy or change the WEP Key there defined.
Hope that helps.
If you need and advice about a new wi-fi router....linksys all the way...;)
Posted on Feb 28, 2009
  • 121 Answers
SOURCE: trying to connect lap top
The WEP key is something you designate on your own router. IF you are trying to get into someone else's router you need to ask them for permission to have their WEP key. Otherwise you cant get in. If you forget your WEP key you can do a hard reset on the router to clear out the key.
Posted on Mar 18, 2009
  • 67 Answers
SOURCE: laptop not responding to my belkin
You would have to login to the router and see what the encryption level is, i.e. WEP or WPA, then you should see a obscure key checkbox, uncheck it to see the plaintext of the passphase, if the checkbox is unchecked when you log in then you should be able to see exactly what they are... Hope this helps!
--Joshua79
Posted on Apr 05, 2009
  • 497 Answers
SOURCE: I have a wpn824-2 and I am trying to set up a
You can get the WEP or Network Security Key from the Router.
Login to the Router as follows (make sure that it is connected to the Computer using LAN-Wired connection):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.1 as the URL.
3. Type "admin" as user name and as "password" as password.
4. Go to the "Wireless Settings" option.
5. Set the Wireless Network Password (either WEP or WPA key) will be listed next to Security Encryption.
You may also use any third party utility to get the Wireless Security key save in the Computer (in which wireless connection is working and key is saved).
Good Luck!!!!!!!!!!!!!!!
Posted on Nov 20, 2009
anil_valayil
  • 218 Answers
SOURCE: trying to get on internet but its asking for a wep
The password it is asking is the password you gave when you set up the router. Well. before going further, if I may ask, Have you gone to the web page http://192.168.1.1 and used the username: admin, and password as password or 1234? Have you set up the information in that page? If not you need to do that. At that time it will request you a password. And it will ask you for the type of security you need. WEP is one of the choices you can opt which means wired equivalent privacy. Such connection needs you to provide a password. Every time you try to connect a new device like a laptop or PSP it will ask you for this password. If you have doubts about this procedure easiest way is to call the customer support. They will take you step by step. Please note at times it could involve half an hour to complete the whole process. Having said that it would be a good idea to choose WPA. This Wi-Fi protected access. You can further enhance security by choosing Mac filter. Honestly, it is not an extremely difficult process. You can try on your own. Mac address filtering means every device like computer or PSP has a device address. ONce you use MAC filtering The net work will only allow those devices. Every time you wnat to add a new device you can go online and add that mac address there and then add that device to your network. Good Luck.
Posted on Jan 25, 2010
Lap top asking internet security key
The security key is the wireless router's encryption key.
Depending upon the wireless router's settings this encryption key could be the WEP or WPA or WPA2 or a passphrase. The encryption key can be generated using a phrase (passphrase) which generates a group of hexadecimal numbers.
Dec 28, 2010 | Computers & Internet
I sent my lap top in for fixing so I got it back and I am trying to connect to internet and it states it needs a WEP or WPA Network Key address to type in can you help me with this? my other email is...
1. Your router is the issue. It is asking for the WEP password or Network Key.
This is set up in the Wireless router.
You either know the password or have it written down.
If you are the administrator of the the router and don't remember the password or user name you will have to reset the route to factory default settings and go through the setup wizard and choose and create and save a new user name and password / WEP/WAP key. Consult your router cd for the instruction set. It will walk you through.
Jul 07, 2010 | Belkin (F5D7230-4) Router (587009)
Trying to get on internet but its asking for a wep key or a wpa key I just completed hook up to netgear router have desk top and a wirerles lap top laptop is asking for info
The WEP and WPA key is configured in the router's wireless settings.
WPA is a stronger encryption than the older WEP encryption, I suggest you use WPA or better still WPA2.
To secure your wireless network, configure the wireless router and the wireless card in the computer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 25, 2010 | Computers & Internet
I have a wpn824-2 and I am trying to set up a connection from my lap top. It is asking me for a network key or wep key. Where do I find it?
Nov 19, 2009 | NetGear RangeMax WPN824 Wireless Router...
Laptop not responding to my belkin
--Joshua79
Apr 05, 2009 | Belkin (F5D7231-4) Wireless Router
Trying to connect lap top
Mar 18, 2009 | Buffalo Technology WHR-G54S Wireless...
How do i find the wep number for my router
Log into the router with your working laptop and retrieve the web key
Mar 02, 2009 | Belkin N1 Vision Router
Can't find wep key
Hope that helps.
Feb 28, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Connecting my new laptop to the internet
There is a wirless icon in the botom right corner of the screen right click it and say view all wirless networks. lock for the one you own say conect it might ask for a WEP password which is located on the botom of the router that is if you did not change it from the defult.
Jan 03, 2009 | Zyxel Prestige P-330W Wireless Router...
Connecting lap top
If this is a new router you will find everything you need in the router's manual. You will need that to set up the WEP key. If the router has been used wirelessly before, then you will need the WEP key to set up the connection through the windows wireless connection wizard. If you don't know the WEP key, you will have to connect to the router with a cat-5 cable and access the router that way with your internet browser to find the WEP key, or generate a new one. You'll need to type in the router's IP address in the address bar of the browser.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 26, 2008 | NetGear DG834G Router
Computers & Internet Logo
114 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
