Question about Magic Chef 9512 Electric Single Oven
Oven problem When I push the bake button, the lock light comes on and I can not use the oven. The self cleaning lever is not pushed over.
  • 1 more comment
  • Scepter Nov 29, 2007
    Not sure about the style of oven, its a Magic Ched, Proven Cook Performance, Super Capacity, I am a renter and dont have the manual
    Its electric with a smooth top
  • Anonymous Dec 30, 2007
    Same problem but its a magic chef 3730 gas range.
Sam problem here
Posted on Apr 05, 2008
Have a wall mounted Jenn-air oven. Have used self-cleaning feature before. Followed step by step instructions to the end including locking the door and pushing "Enter". Went to bead expecting to wake
This is a general answer and not specific. The oven thinks is still in the cleaning mode. If it has one, push the clean button again. Set the oven to a regular bake cycle.
Dec 15, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
We a kitchen aid oven the door was accidentally lock. Can you find out how to open it? Whirlpool owns kitchen aid
  • Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3
    Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4
    Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • Nov 18, 2012 | Ovens
    F7 shows instead of door lock
    This happens with a lot of ovens. It's because the mechanism that locks the door is stuck. When the door doesn't lock you can't do a self clean. They don't want you to be able to open the door while the oven is 800 degrees? or so. Look just below the little button that gets pushed in when the door is closed, upper left, and you should see a vertical slot. This is where a little lever comes out and grabs the slot on the door. There is a microswitch inside that tells the oven if the lever has come out or not. Your lever is stuck.
    You can test this in a totally dangerous way by opening the door, holding in the button, and turning on the self cleaning. If everything is correct you will see the lever come out to grab and lock the door, but your's won't because it's stuck. Jiggle it or push on it or pull on it with needle nosed pliers. It frees up pretty easily. But when it does, the oven will go into self clean, which you don't want it to do with the door open, so turn it off, close the door and try again. It should work fine.
    Dec 01, 2011 | Fisher and Paykel AeroTech OS302 Electric...
    Cannot unlock oven door
  • Here it is!
    Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    How do i unlock a de dietrich oven?
    In order to unlock the oven you need to perform the following:
    Jun 25, 2011 | De Dietrich Ovens
    I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Jan 18, 2011 | Kenmore Ovens
    How do I clean my oven? Model #RF354BXWD?
    At the bottom of this is a link to the manual, it shows details starting on page 22 of how to clean.
    Remove the racks and pans from the oven.
    1. Move the Lock Lever to the right-the Clean position.
    When the oven temperature goes above normal baking/roasting temperatures, the door cannot be opened and the Lock Lever must not be moved.
    2. Set the Oven Selector and Oven Temperature Control Knob to
    CLEAN.
    3. Make sure the clock and Start and Stop Times all have the correct time of day.
    4. Push in and turn the Stop Time Knob clockwise two or three
    hours. The OVEN HEATING Indicator Light will come on. l Use two hours for light soil. l Use three hours or more for moderate to heavy soil.
    NOTE: Make sure the Start Time Knob is not pushed in.
    5. After the Self-Cleaning cycle is completed and the oven has
    cooled enough, the Lock Lever can be moved back to the left.
    DO NOT FORCE the Lock Lever. Wait until it moves easily. Turn the Oven Selector and Oven Temperature Control Knob to OFF.
    6. After the oven is cool, wipe off any residue or ash with a damp cloth.
    If needed, touch up spots with a soapy steel-wool pad.
    Manual
    Jul 30, 2010 | Whirlpool Ovens
    How do you operate oven
    You should have a bake and broil button and arrows to adjust temp up and down. Of course a start button should be there. If no off button, then there should be a cancel button to turn it off. The door only locks in self clean mode.
    May 21, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    HOW TO UNLOCK THE OVEN DOOR FOR THE DIETRICH OVEN MODEL DOP440BE1
    Thank you for contacting Fixya.com
    Aug 07, 2009 | De Dietrich Ovens
    Kenmore oven locked door light on but not, won't bake
    Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
    Jan 12, 2009 | Kenmore 47783 Electric Single Oven
    Magic Chef 9512 Electric Single Oven Logo
    164 people viewed this question
    Top Magic Chef Ovens Experts
    Sal De
    Oloyede Monsuru
    Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
