Question about Tascam DP01FX All-In-One Recording Package Microphone
PLEASES, PLEASE, HELP!!!
Hi, thank´s to take the time to help me
I have a tascam DP 01/FX and i was copy a song when appear this legend : "song complete" but it´s not working since that thing happen. And when i turn on say "reading song" but its not working, not any key, not any function. I try something, (cause sometimes work in other instruments) i press the key "shut down" and the key "track edit" to 3 seconds, and after that i tur on the DP 01/FX and this is that can read "initialize HDD... are your shure? i dont want to lose my songs, and anything i have on my tascam. what can i do?
helpme if you can, just tell me what to do
thank´s a lot and please for my bad, bad english
  • Chan Lee Sep 01, 2008
    Will not initialize past reading song. Previous to this and shut down, the instrumental I recorded was skipping about 1-2 second loops with all effects thru the machine were sounding correct in the headphones. I tried erasing the song and starting over. When I turned it back on to re-record the instrumental it would not re-initialize. All effects buttons indicator stuck to on as it freezes on the last step of reading song.
SOURCE:
  • 189 Answers
SOURCE: Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Posted on Jan 03, 2008
  • 189 Answers
SOURCE: Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Posted on Jan 05, 2008
  • 189 Answers
SOURCE: what kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Posted on Jul 24, 2008
  • 189 Answers
SOURCE: memory poor
This is an error in Tascam's code that usually means 'out of disk space'. Try using 'delete unused' to free up some space first within the song you're on and after that you might consider backing up some songs to your PC and then deleting them from the DP-01 to free up more disk space.
Hope this helps.
bd.
Posted on Dec 15, 2008
  • 1140 Answers
SOURCE: HELLO,
You need a PS-1225 power adapter. According to them you should use only that power supply. It has +12 volts out at 2.5 amps. The center pin is + and the outside shaft is negative. It is 100 to 120 VAC at 15 watts power consumption. You may be able to use the supply for the newer DP-02. The 01 is discontinued. If you decide to make one yourself, make sure the specs are exactly the same and the polarity is correct and the plug size is perfect.
Posted on Jul 10, 2009
Cant transfer the master from tascam to computer
I'm assuming this is a Tascam recorder you're refurring to. What model is it, and what operating system are you using on your computer. First off, don't connect the usb cable to the computer until your Tascam Recorder in in USB Mode. I have the Tascam DP-01. With it, after making the master recording, make sure the master light is off, and not flashing. In the menu under WAVE, select Export Master and press enter. If anything is running, or the master light is lit, you will get an error. After the song is saved to the FAT partition, select DISK in the menu and scroll down to USB Open/Close and press YES/Enter. You'll be asked if you are sure. press Enter/Yes again to go into USB mode. Now plug in the USB cable. Use Windows Explorer, or what ever file navigation program is on your computer. (Not Internet exploere, but windows exploere.) Your Tascam will be seen as Removable Media when viewed from your computer. I have a DP-01, and it shows on my computer as DP-01. You'll find a few folders viewable on your recorder. One of them is called WAVE. You'll find your Exported Master in this folder. Copy it to a folder on your computer. When finished, if you're using windows, then use the Safely Remove Media function in the system tray where the clock is to disconnect from the Tascam safely. Then unplug the USB cable and press NO/Exit on your Tascam recorder to exit USB mode. I hope this helps. Have a wonderful day.
Jan 08, 2015 | Tascam Audio Players & Recorders
Is there a driver for tascam dp-01 for windows7 operating system
Unfortunately no such driver is available, because tascam have discontinued that particular model.
Here is a way to get your recordings off the device
On the Tascam main menu, select "Wave." 2) On the Wave menu, select "Export Master." This saves your mastered song to the correct folder. 3) Connect the Tascam DP-01 to your computer. You will get a message telling you your USB device has malfunctioned. 4) On the Tascam menu, select "Disk." 5) On the Disk menu, select "USB OPN/CLS." Your computer should detect the DP-01 as a hard drive & be visible in "My Computer" on Windows.
Apr 03, 2011 | Computers & Internet
How do I split up one song on a Tascam DP-02 into more songs?
Hi, I think the proper way to do this should be to copy and paste a section of the track using in and out points to mark the section you would like to copy on to another track but I have been unable to figure this out! very frustrating! However for now I have managed to do it this way (The long way round but it works) say a track that I have 10 or so songs on, I copy it say 10 times (this takes a long time!) When you copy them they show up as the same title. I then rename the original so that i don't mess about with the original! Then I set in and out points previous to the song I want to get to another track and press cut. I then set in and out points after that song and press cut this leaves you with just that song and it is at the begining of the track because cutting closes up the gap. I save and rename this appropriatly. I then do the same for alll the other songs I want with the other copies.!!!!!! Hope this helps, if you work out how to cut and paste please let me know!
Nov 11, 2009 | Tascam Dp-02cf Digital 8-track Recorder
My computer won't recognize my DP-01 Tascam recorder.
open the usb port on your dp-01 by going to "disk" in the "menu" select "usb opn/clse" press enter twice.
if your pc is connected to ur dp-01 it should reconize it, open the files by going into my computer as you would with a memory stick or card.
Mar 25, 2009 | Tascam DP01 All-In-One Recording Package...
Memory poor
Hope this helps.
bd.
Dec 04, 2008 | Tascam DP01 All-In-One Recording Package...
Itunes connection
yes they are lost and you would have to turn on write protection. better idea is dont use itunes invest in a better online catalog.
May 18, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD
Check to find out the size of the active FAT partition. You may have a 'less than optimum' amount of memory left in that partition. Switch to another partition and see if you can record in that one.
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Ekse
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
