Question about Sony PlayStation Portable (PSP) Console
Psp i need to change both front and back of the faceplate can you help?
  • 79 Answers
Hi knighty1,
go to http://www.psptree.co.uk/store they have replacement parts for almost everything PSP related!
Please rate if at all useful, thanks!
Posted on Nov 30, 2007
SOURCE:
Psp wont power up .
psp unable to restore games from memory stick
Jul 03, 2009 | Sony PlayStation Portable (PSP) Console
My analog stick is stuck in the upwards direction. Every time I play a game, the character in the game always moves up and in the game menus, the highlighted option always keeps moving up. I really don't...
Sony is full of it. Yes you can repair it. All you need is a brand new nub (joystick). You can find it on the net for about $5 less shipping depending on your model it is not hard to replace. On a phat (old school psp there are seven screws holding the faceplate. Once the faceplate is off there are two screws holding the nub in place. The slim is almost the same there is seven screws holding the faceplate but the only difference is the last two screws you have to take off is on the top. And once the faceplate is off it's the same two screws holding the nub in place. Replace and screw back in.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
I have bought a new faceplate for my psp and I don't know how to take off the original.
Since your replacing the faceplate only, only remove the screws on the outside border. not the two on the right side of the battery.
* The bottom silver screw (located on the bottom part, opposite the top part, which has the USB port)
* The top left black screw (underneath the battery)
* The bottom left black screw (underneath the battery and the left side of the warantee sticker)
* The top right screw (located on the back side of the psp in a hole on the outer casing)
* The bottom right screw (located on the back side of the psp in a hole on the outer casing)
Then do the reverse to put it back together.
Dec 18, 2008 | Video Game Consoles & Games
Psp Problem
THESE STEPS WILL VOID YOUR WARRANTY!!!
You will need:
1 Fairly Small Screw Driver
Something Soft to protect your screen (Optional)
Something sticky to hold your small screws (Optional, but recommended)
Ability to remember where you removed screws from =D
1. Flip your PSP on the front side (screen side).
2. Unscrew the two screws on the outside opposite of the battery.
3. Open the battery panel, and unscrew the screws under the battery.
4. CAREFULLY, take off the faceplate and make sure your L/R buttons are properly secured and clear from dust/dirt.
5. Check the 'Home', 'Start', etc., buttons for anything that may "jam" them.
6. Reassemble your PSP by screwing the screws back into their proper areas.
AGAIN, this will VOID any warranty you have and I AM NOT responsible for any damages to your PSP!!!
Sep 18, 2008 | Sony PlayStation Portable (PSP) Console
My psp is scratched in the inside of the screen
.Actually will be helpful to find if you unit is been damaged from a scratch or a Crack display.The one on the front is Called Faceplate.The one inside(the lcd is called screen).
If your screen is cracked you can order one on line and follow some tutorial.If the scratch is from the faceplate you can try to open the machine and clean the scratch with some plastic polish
Good Luck
Jun 19, 2008 | Video Game Consoles & Games
Faceplate starts flahing and no controls work.
Sounds like you might need to clean the contacts on the back of the faceplate or the ones on the front of the actual unit.
Jan 18, 2008 | Kenwood KDC-MPV619 CD Player
Psp "R" Button problem
Hi Erikthug22,
You will have to open up your PSP to get to the contacts of the R button.
  1. REmove the battery
  2. Remove 4 screws from battery compartment
  3. Remove 1 screw from front edge under the PSP logo.
  4. Remove 2 screws from back on opposite side of battery.
  5. Lift the faceplate from the edge above the LCD slightly.
  6. Lift the front faceplate edge under the Home/Start button.
  7. You need to be very protective of the little screw hole that is under the PSP logo of the Faceplate..
  8. Do not touch the LCD screen if you can help it. If you do use a lint free cloth and windex glas cleaner to remove fingerprints and lint. Same thing for faceplate window.
  9. REmove the R button
  10. lift the rubber pad/frame behind the R button straight up.
  11. Clean the back of the rubber piece with a Q-tip and Rubbing alcohol.
  12. Clean the contact pad that is behind the rubber pad/frame.
  13. Press the rubber/fram piece back into place carefully.
  14. Put your R button back on.
  15. Be sure your LCD sreen and inside of faceplate window are clean.
  16. Refit the faceplate.
  17. Reinstall screws.
Nov 04, 2007 | Sony PlayStation Portable (PSP) Console
Replacing the back of a psp
www.llamma.com look for the PSP page.  Be careful with the backlight cable connector, the dark colored release flips up reverse, back to front to release the backlight cable..
Pictures and tutorial on LLamma.com
Oct 20, 2007 | Video Game Consoles & Games
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
THE POWER SWITCH
If it's under warranty send it back, if it's not then do this. Order a replacement power switch online, ebay is pretty good for psp parts. There's 5 screws holding the front cover of the PSP together two on the right that are recessed, you'll need a long skinny precision screwdriver , there's two more under the warranty stick behind the battery and one more in the middle of the silver metal piece. The power stick assembly is a separate board that plugs into the psp and a easy repair. Just be careful once you remove the faceplate one dust particle and you'll be taking it apart again to clean the inside of the screen.
Jan 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
