Apple dvd driver
I need an Apple Driver for Sony DVD AD7190A. I have it in a G4 powerMac MDD running OS10.4.11
  • John85746 Dec 07, 2007
    When I first tried the drive I added it as a second optical reader and my Mac said not supported. I later put it back but pulled the cd reader. It now works as it should. Thanks for your help. I'll research two devices at a later time.
  • 37 Answers
There are no drivers it is plug and play
Posted on Dec 07, 2007
  • paul shaw Dec 07, 2007
    so have to get someone to write u one or better still get one that comes with a driver for apple
Need component identification for G4 powermac
Which component? There are a lot of them. Memory type is printed on each stick. Hard drive and DVD burner are IDE and are interchangeable. Anything connected by USB is plug and play. For Mac ID go to About This Mac menu bar, upper left shown as an Apple logo. First screen will tell you OS, RAM and processor. Click on More info to see a detailed profile.
Apr 09, 2013 | Computers & Internet
I attempt to burn a DVD with video footage however it just stops burning and will not continue!!!...I don't know if this is a power supply issue or not !!!
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 27, 2011 | Apple Power Supply 338 Watt PowerMac G4...
I would like to connect an Apple Studio Display 17" to my Macintosh Server G4. Can it be done? What adaptor is needed if any?
Apple Studio Displays connect via DVI cables. The PowerMac G4 (all versions) support both VGA & DVI. You shouldn't need any adaptors. It should just plug into the back.
Dec 22, 2010 | Apple Macintosh Server G4
I have a G4 PowerMac Sawtooth which was given to me, it has an OWC 1 GHZ. PowerPC CPU processor board with the gold colored heatsink and single fan. It has 1GB of PC-133 RAM and the latest firmware...
It is possible you have a power supply failure. My MDD was doing the same thing unless I reset the PMU. There is a tutorial here on checking the PS - D275729F-09DA-4FBB-96B3-BEEEB2C04619.html It for a MDD, but I would think it would be useful for your situation.
Do you have an Intuos tablet connected? The drivers for that might be causing the problem and should be updated to the newest driver available
Oct 10, 2010 | Apple Power Mac G4 Desktop
Which webcam should I purchase?
Unless you plan to use it as a HD video camera  the cheapest one with a mac driver will be just fine.
Nov 16, 2009 | Apple PowerMac G4 733Mhz with 256 RAM,...
Imac g5 ejecting dvd/cd media
most likely, your dvd burner lens is burnt out(they make the darn things out of plastic!). Just happened on mine. you have to either replace the drive or get an external. There are do it yourself instructions on Apple's website for replacing the drive.
Not all drives are compatible...must be slot loading and I read that it has to be set to master so you can potentially boot from CD's in this drive.
Jan 02, 2009 | Apple Wired Mediapress X SDI MPEG Encoder...
PowerMac G3 connections and compatibility
You need a adapter from your serial port to usb/also yu need to update your os to 10.2 or 3
Dec 01, 2008 | Apple iMac G3 Desktop
Power Mac G4 MDD manual
Hello mate.
Here you go: http://www.apple.com/support/manuals/powermac/
Nice pc btw, i got the same pc, just Power Mac G5.
Good Luck.
Thanks,
Best Regards
MudiW
May 25, 2008 | Video Game Consoles & Games
Need User or Owner's Manual for Mac PowerPC G4
Mac help is built into the operating system on your computer. There really aren't any paper manuals for them. Here is a link to Apple's web site that should get you started: http://www.apple.com/support/imac/g4/
Dec 28, 2007 | Apple Macintosh Server G4
Why won't my computer read it?
Finalize the disk in the computer.
Jul 31, 2007 | Toshiba D-R5 DVD Recorder
Computers & Internet Logo
Alun Cox
David Payne
David Payne
