Question about Logitech ClickSmart 310 Digital Camera
Software loading into computer problems...
Cannot get the software to load into my computer(that I got with the camera)is there a way to get it off of the net as freeware?
  • lesfox Aug 22, 2008
    When I put the CD in the computer it does not load.
  • brian c
    brian c May 11, 2010
    What version of windows are you using?
I found my webcam but i cant get a software for windows vista
Posted on Mar 22, 2008
SOURCE:
My fine pix JX300 wont let me down load photos to my computer and says i have a driver problem
Install the software that came with your camera. Make sure software is compatible with your operating system.
Apr 12, 2014 | FUJIFILM FinePix JX300 / JX305 Digital...
Kbainbridge
Most common problem is, people forget to put the correct software on the PC (or MAC) so the computer knows it should load pictures. For most equipment, drivers are loaded automaticaly, when it is connected to the computer. But the software that is delivered with the camera is needed to load pictures to the PC. If you don't hav ths software, you could try to get the pictures to the PC with a card reader. That does not require extra software.
Nov 08, 2013 | Cameras
Down load to my window 7 , said not compatiblle with system. It will not let me down load to computer.
There are 2 different solutions available for this problem,
1. Reinstall the Sony Cybershot software that came alongwith the camera, update the software online and then try again (may need a PC restart).
2. Alternative way is to take out the SD-card from the camera and upload the pictures using a SD-card drive or USB stick.
Hope this solves your problem.
Feb 18, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
Fuji svp t718 camera will not download pictures to my computer. hooked up usb cable and it just says on camera screen usb connecting. nothing else happens. what can I do?
In order to down load pictures from a digital camera to the computer, you must first load software that allows the computer to recognize your camera. There should be software that came with the camera, and how to load it is in your manual. If you choose not to do this, then you can take the memory card out of the camera and insert it into a card reader attached to your computer and see the pictures on the card.
Feb 14, 2011 | Cameras
Picture file size too big when loaded into easyshare software
Upgrade you computer.
You could also lower the quality of the pics on the camera.
Menu, Camera Settings. Pixel Quality.
Nov 22, 2009 | Kodak EasyShare DX7440 Digital Camera
Camera worked ok on XP new computer cannot load
Try This Software: "Driver Genius" After Installed Plug In Device (Camera) Click SCAN And Install Drivers (note u can chose whichever drivers u want to install), Very Easy To Use Software
Nov 21, 2009 | Logitech QuickCam Express Web Camera
4100 vivitar has pics and sd card, will not load pics on pc.
Battery Drain is probably the problem
Best bet?
But a Card reader.
And if you have camera software loaded -unload it
Windows does it better.
Nov 09, 2008 | Vivitar ViviCam 4100 Digital Camera
Downloader says no pictures on camera
Depending on the version of software you have the drivers may not have loaded correctly. Try using a USB port on the back of your computer and see if it loads the drivers then. If not you may need to reinstall the software and the downloader. You may need to uninstall the DB CIF Cam depending on the version of software you have. The reason for this is if the camera was connected to the computer before the software was installed then Windows loads the most generic drivers it can find for the camera. From then on if the camera is connected to the computer Windows continues to load those drivers and not the correct drivers. Simply connecting to a different port can correct this or reinstalling all of the software can correct this.
Aug 30, 2008 | Disney Pix Micro Digital Camera
Pictures wont down load
If the camera software is loaded and you are connecting the camera to computer.
Remove the softwaree and.
Windows will see the camers as a removable memory device in my computer an put up the scanner camera wizard.
This may reveal more.
You may also have inadvertantly deleted stuff
download www.pcinspector.com
install it to recover any deleted images.
Also try the camera and card in another computer.
Aug 12, 2008 | Cameras
Logitech ClickSmart 310 Digital Camera Logo
Top Logitech Cameras Experts
David Hoff
Bill Boyd
Marvin
Marvin
Are you a Logitech Camera Expert? Answer questions, earn points and help others
