HP HP Compaq Presario CQ60Z Notebook PC - 2.1GHz; 250GB HD; 2GB Memory
Problem for HP HP Compaq Presario CQ60Z Notebook PC - 2.1GHz; 250GB...
Compaq Presario 2500 Laptop fans not turning on since....
By ishmael9100 on Aug 13, 2009
....I cleaned the dust with an air duster. I noticed my laptop was overheating really quickly so I decided to clean the dust because i thought it was the dust clogging up the fans. So i used an air duster and managed to get almost all of the dust out. My previous problem with the automatic shutdowns was sorted. What happened was that my laptop has a heating limit so if the laptop temp is higher than the limit it will automatically turn off with no warning. So now my laptop would shutdown because the fans are not turning on.
Any solutions?
Thanks!
Best Solution
posted on Aug 13, 2009
Very Helpful)
bob_computer
Rank: Guru  HP Computer Hardware  Expert
Rating: 87%, 1249 votes
First check in the BIOS to see what you can set for thermal limits.
When you blew out the dust I do hop you did not poke the nozzle into the laptop as this could cause damage not only to the laptop but to the fans a well. I also hope you did not do this with the laptop switched on as that too could cause damage.
Many compaq also ship with a small utility program that also allows you to set temperature limits. make sure it is set back to defaults and that you only make adjustments from here if you live in an extremely warm climate
You should also consider the use of a laptop cooling stand with at lease two fans preferably more. A good laptop cooler can be a lifesaver for a laptop.
If this information was useful please click below.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" I did not poke the nozzle into the laptop becuase i know the consequenses. The laptop was not switched on too. I took all of the dust out and the fans just stopped working. Its quite an old laptop so i can't really get angry because i know what to expect. It was given to me free by a friend and the laptop is from italy so i dont really mind. Thanks for helping! " - ishmael9100
Popular Solutions for HP HP Compaq Presario CQ60Z
Questions and Unsolved Problems for HP HP Compaq Presario CQ60Z
Do you recommend HP HP Compaq Presario CQ60Z Notebook PC - 2.1GHz; 250GB HD; 2GB Memory ?
Answer
Answer
will not install office 2007 asks if I want to save .exe as a binary file
Answer
got this laptop from my friend,and he locked the bios acces and windows vista too,so impossible to... (More)
Answer
Yaz...the application has failed to start because rtl100.bpl was not found.Re-installing the... (More)
Answer
am connecting laptop asus pro321f to plasma 42 inch with dsub connections...after an hour or so it... (More)
Answer
can not download programs it says internal error "userappdata"
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
