Washing machine shuts down in spin cycle
My machine will shut down in the spin cycle, but if I move the timer handle one notch and push and pull the start knob in the center of the timer I can get it to start up agian - any idea which part I should look at for fault???
    President:
  • 1,294 Answers
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground.
Posted on Nov 30, 2007
The spin dry of the above mentioned washing machine spin dry not working properly cuts off what parts are required to fix this ?.
If a machine is out of balance when spinning it will shut down---there's an unbalance switch that controls this---also on some machines if not properly set level or feet not touching the floor causing the machine to rock---it will shut down---the remedy for that is to redistribute the clothes then is should resume spinning----another issue could be the timer----out of sequence or jumping ahead during that cycle---has the timer/control ever been wet as this will cause some issues---this is my thoughts on this--good luck
Mar 16, 2015 | Washing Machines
Spin cycle
sounds like a faulty timer unit.
Aug 26, 2013 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washer bad timer
it very much sounds that the moving parts the timer are worn or seize recommend new timer
Nov 23, 2017 | Whirlpool Washing Machines
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
GE washer won't complete cycle
there are contacts inside timer which may not be working properly. in any case they are not repairable.
Oct 28, 2009 | GE Washing Machines
Kitchenaid washing machine not spinning
WHEN YOUR WASHING THE LID MUST BE SHUT BEFORE IT WILL GO INTO THE SPIN CYCLE. UNDER THE LID YOU WILL SEE A PROBE THE PUSHES THE SWITCH DOWN WHEN THE LID IS SHUT. THESE SWITCHES WEAR OUT , ONE THING TO TRY WHEN THE WASHER TRIES TO GO ONTO SPIN TAKE A NON MATALIC ITEM AND PUSH THE SWITCH DOWN AND SEE IF THE WASHER GOES INTO THE SPIN CYCLE, IF IT DOES THE SWITCH IS NOT BEING PUSHED DOWN FAR ENOUGH TO MAKE THE SWITCH WORK
THIS IS VERY COMMON ON ALL WASHERS
Aug 12, 2009 | KitchenAid Washing Machines
Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Keeps filling up even when full for over 4 hours (never changed cycles)
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Jan 13, 2008 | Maytag Performa PAV2200
Washing Machines Logo
195 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
