Question about BenQ FP71E 17" LCD Monitor
Monitor FP71E turns black
Need help! I have had this computer system now for three years and just started having a problem. My monitor turns black and will not come back on. Before all I would do is move the mouse and my desktop would reappear now nothing. I turn the monitor off and on, even turn the computer off and on and nothing happens. I have to turn the whole system off and wait approximately 20min before turning it back on. I confirmed that it was not going into sleep mode. I even made my screen saver go on after one minute and it is still happening. Can anyone help.
Your monitor rectifier is dead you need change transistors С5707 and check the Capasitor big one!!!!
Posted on Jan 07, 2008
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
Screen is trying to black out on me, accompanied by a loud buzzing noise. This buzzing noise has been growing over the past few weeks, and now, today, my monitor has blacked out several times, at which...
well mine came with a three year warrintee, so iv sent mine back twice already, worst moniter, try finding your receipt and then going on to acer's online support
Dec 15, 2010 | Acer X233H 23" Monitor
Screen appears on for three seconds then goes black
Try the monitor on another computer that you know works, If it works on another computer then that means you have no video output on the original computer and you'll need to reseat the memory on that computer.
If you get the same response on another computer, then that means the monitor is bad and you'll need to replace it.
Apr 19, 2010 | Samsung Syncmaster 2033SW Monitor
Black screen after a year of use
Sine a flashlight on the screen and check for a dim image. If you see a dim image the back light needs to be replaced. After doing that you will want to try using another monitor cable and see if that helps. If it doesn't with the computer on and the monitor on disconnect the cable from the computer. If the monitor shows a no signal error the graphics card needs to be replaced.
Sep 07, 2009 | Acer AL1916W 19" LCD Monitor
The monitor was working one day and the next day, it would not come on, screen black. My grandson has had the monitor for almost three years.
I'll hope for the best and assume the simple fix first. Check the plug at the back of the monitor to insure it wasn't pulled out slightly. Sometimes, moving something around can cuse the plug to lose proper connection.
Also, check the power source to insure that you have power to the unit. We had a lightening storm recently and the power strip surge protector did it's job. I turned it back on and everything powered up again.
I hope this helps... Good luck!
Sep 02, 2009 | Computers & Internet
MONITOR COMES ON FINE I GET A FLICKER AND THE SCREEN GOES BLACK
It’s very likely your monitor has failed. Most Dell monitors have a 3 year warranty, so if you got it before three years, you could get it replaced by calling Dell. If you got the monitor with the computer, you can check your warranty online from with your computer Service Tag from http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen . If you bought the monitor separately, you would need an Order Number or Customer Number for the purchase, or you could call Dell support and they could pull it out with your registered phone number. Dell would also need the serial number (starting with CN XXX..) from the back of the monitor.
Monitor User guide for SE198WFP available at http://support.dell.com/support/edocs/monitors/SE198WFP/en/preface.htm
Hope this helps. Please rate your feedback!
Thanks,
VJ
Mar 24, 2009 | Dell SE198WFP LCD Monitor
CHIMEI CMV T39D
Sorry to hear that you are having problems with your monitor. While the monitor is turned on and plugged up to your computer system, try looking very closely at sharp angles from above, if you can barely see your desktop the problem is the back lamp inside your monitor. Make sure the settings are not in sleep or standby mode first. If it is your back lamp you can check the following websites for information on how to fix them: The first one is here
The second site requires free registration and you will find the information you need in the members section, the main page is here. Since your monitor is less than a year old, you might want to consider sending it back to the manufacturer since they usually give you a 1-3 year warranty on the products. The only thing you should have to pay is shipping and handling. You stated that you changed the cables and tried hooking up the monitor to a known good system and that still did not help the problem, so I believe the problem may be the back lamp. I hope this helps fix your problem and if you need further assistance please let me know. I wish you the best of luck.
If you would not mind rating my help, I would really appreciate it. Thanks
Jul 07, 2008 | Chi Mei Corporation CMV-T39D Monitor
Plug and play PL716s proview monitor
after almost two/ three years my monitor is starting to give me trouble its comes on then it blinks off I have to constantly turn the power button on and off I cannot keep it on. Please help.
Jun 19, 2008 | Envision EN-7220 17" Flat Panel LCD...
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
BenQ FP71E 17" LCD Monitor Logo
187 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
