Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung Rear Projection DLP HDMI Captions
Hi I have a Samsung Rear projection DLP. I just hooked it up to my cable box (HD cable box from Time Warner) I change the input to the HDMI on my TV and now all of my channels come up with captions. picture and sound are fine but I can't seem to turn off the captions. Any ideas?
Thanks!
Sara
    President:
  • 1,284 Answers
The captions are turned on in the cable box itself. If you have a Motorola cable box, turn it off then hit the menu button for the cable box. You will then see where you can turn off the closed captioning. Anymore questions email me tvtek@msn.com
Posted on Nov 30, 2007
I am hooked up to At&t uverse through a DVR. It works fine except when HD light on DVR indicater comes on then TV and sound go blank. Could it be that this TV doesn't support HD?
Some DLP tvs support HD some don't.Easy to find out.Ur tv have any HDMI ports for the HDMI cables to hook up in?Yes,it support HD,no HDMI ports,than it dosen't support HD.
Oct 26, 2010 | Sony KP-53HS30 53" Rear Projection...
Toshiba 57h82 "jittery" Screen
I had the same issue and i hooked my time warner cable box up and turned it to an hd channel and it comes in perfect so i set the output to only 1080i and now i can view every channel perfect
Feb 24, 2010 | Toshiba 57H82 57" Rear Projection...
Hooking up blue ray to Samsung 1080 DLP
if the tv is not a 1080p model it will not accept a blueray signal and the optical output from the tv only works thru its own tuner not with the inputs or cable boxes
Jan 31, 2010 | Samsung HLN617W 61" Rear Projection HDTV
2004 hlp4663w component and hdmi signal error message
Chances are the analog board ( One with the Inputs) need replacement. You can get one at the following link. www.tvrepairworld.com
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I cannot tell the difference between my SD channels and my HD channels. I have samsung DLP tv, HD cable box and bose theater system. I am using an HDMI cable but there is not difference between that and...
In most cases you will not be able to see a great difference between HDMI and Component connections. As far as not seeing a difference between HD and SD signals from your cable box, go into the settings of it and see what resolution it is putting out. If you have a Motorola cable box, with it off and the TV on press the menu button and the setup screen will appear. That will tell you the output resolution as well as what the 4:3 override is set to. Please take a few moments to rate my answer. Thanks....
Nov 22, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I just hooked up a Time Warner Cable 4250HD Box via HDMI to DVI cable to a 50 inch Sony Grand Wega. The problem is on some channels the bottom of the screen (like a news crawl) gets cut off. This happens...
You need to make sure that the settings on your TV for the DVI connection are set properly. It sounds as if it is set to stretch or zoom. The reason the HD channels look great is that they dont zoom because the resolution fills up the entire screen without stretching.
I know you want to use your HDMI cables, but since you are going HDMI to DVI you are removing the benefit of the single cable since you still have to use audio cables. You are not going to get any appreciable difference between the setup yo uare using and the component (red, green, blue) cable.
If I have helped you, please rate me as such. It allows me to help others. Thank you.
Aug 06, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Bottom of screen gets cut off.
you need to press the aspect ratio button to change the view is should bring up the news ticker into view if you have your view set to smart try pressing up on the d-pad in the middle of the remote
Aug 06, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have a Samsung HLP5063wx xaa and I am getting a HDMI not supported when I hook up my HD-DVR, any help on how to resolve this, PLEASE!!!
I fixed it, if anyone is having this problem, you will have to tell your Directv box to only accept 720p resolution, I only have one line hooked up to my Hd-DVR right now and I had to tell the Directv box that it was on a Single tuner not Dual, I re-booted the directv box and everything works. I hope this helps anyone w/ an older model DLP, It took me hours on the internet to find the answers I needed.
Jun 17, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Hd hook up for rca 52"dlp
If you have Direct TV HD the best way is to use a HDMI to DVI cable. If you only have the component (red/green/blue)connectors on the Direct TV Box that would be the best way. You will not have audio using the DVI cable, so you will have to run Red/White cable to the Audio Input.
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have Time Warner cable. I just bought a new Sony LCD HD tv and the sound and the video are out of sync on some channels - HD and non HD I am using a HDMI cable. Any solutions that you know of?
Yes there is a simple solution. First, for some reason., Time Warner cable boxes have SERIOUS HDMI issues, including no pic, intermittent pic and sound and the one that you are having. The easy fix is to hook the TV to the cable box using the component connections instead of the HDMI. Normally I would suggest getting the cable box replaced, but I have seen customers exchange cable boxes 3 or 4 times and still have the problem or have a new problem. Use the component connections and be sure to let me know if this works. If it does, be sure to rate this solution. Thanks!
Nov 09, 2008 | Televison & Video
Samsung HLP4663W 46" Rear Projection HDTV Logo
224 people viewed this question
Jerry Greenberg
Jerry Greenberg
