Question about Toshiba TheaterWide 50HP16 50 in. Plasma HDTV
Toshiba 50HP16 - no picture or sound.
Toshiba 50HP16 has no picture or sound. Power is cycling on and off every few seconds. When on, +5 volt is on pin 11 of CP3201 on Scaler Board and 3.3 volts is measured at pin 2 of IC3804 on the AV PCB. When cycling on, D15 lights then D17 followed by D01 on the CTRL-LVDS board. Troubleshooting Guide recommends replacing Scaler Board but I would like to make more measurements. Any recommendations?
  • Plka Bob
    Plka Bob Nov 30, 2007
    Tech8, Thanks for responding but I'm looking for an expert in Plasma TV. I emailing premtech who has been helpful in the past and has service manuals.
  • Plka Bob
    Plka Bob Dec 03, 2007
    MosFets all check out OK. I now have an account at PTS and will send them the board for repair. Again thanks for all the info & Service Manual.
  • 89 Answers
Toshiba 50hp16 has a flashing screen,like someone taking a picture with a flash.sound is Ok.Only 3 yrs old
Posted on Oct 06, 2009
  • 934 Answers
Drummer,
Check mosfet at Q104 2SK2370 which will sub to an Nte2970 on the main power supply. Leakage can cause cycling but my bet is on the scaler board also. You say you have +5v at pin 11 of CP3201 and 3.3 at pin 2 of IC3804 - and all the troubleshooting charts and schematics I've reviewed suggest replacing the scaler board, Toshiba p/n# 72784101 and unfortunately they're about $240.00 dollars. But that sounds like the problem to me...
Bill
Posted on Dec 01, 2007
  • William Rayburn
    William Rayburn Dec 01, 2007
    PS::: I sent the service manual via Pando to your personal addy at hotmail..
    Bill
  • William Rayburn
    William Rayburn Dec 06, 2007
    No problem, let me know how it all turn out...
    Bill
    Sergeant:
    Champion:
  • 298 Answers
Sent me a copy of the schematic
Posted on Nov 30, 2007
  • Eugene Merritt Nov 30, 2007
    Do you have a link to the download
SOURCE:
I have a 6 yr old toshiba 50hp16 that is currently not working. I was watching the tv last night...heard a pop...and noticed the picture got darker and the pixilation got very grainy. The television...
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 11, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Picture but no sound on a Toshiba Theaterwide HD tv
Hello Iam wondering have you tried to see under the TV setting Audio and see if the fuctions are muted
or try to unplugged the tv and wait for a few minutes plug it back in.
Also when th tv is turn back on or unplugged and plugged back in see if the power button light
flashes red
And listen to the speakers to see if there is a faint crackling
Sep 12, 2008 | Toshiba TheaterWide 50HP16 50 in. Plasma...
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16 No Power
I bought a Scaler board from someone on eBay but it did not fix the unit however I'm not sure the replacement was not a dud. I planned to send the board to PTS Corp but haven't yet. I have sent other boards to PTS wit good success. http://www.ptscorp.com/tech_support.html
Dec 29, 2008 | Toshiba 50HP66 50 in. Plasma Television
Toshiba Plasma Power Supply replacement
Its kind of hard to mess up replacing a board in a TV, only thing to watch out for is the board can hold a charge after its unplugged even if its not working. Here is the service manual for your set.
Toshiba 50HP16 Service Manual
Dec 05, 2017 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 50HP16
"Popped"? That sounds like a serious issue that is going to require a warranty repair or a professional TV repair person to address.
May 01, 2008 | Toshiba 50HP81 50 in. Plasma Television
Toshiba TheaterWide 50HP16 50 in. Plasma HDTV Logo
1,818 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
