Question about Canon PowerShot S80 Digital Camera
Canon S80 lens won't retract
My hand holding the camera hit a cabinet while I was taking pictures but the camera was not hit directly. After which the lens won't retract, I get an "E18" error and can hear noises from the camera like motor running when I try to open the lens cover all the way. I saw other postings for the same problem but not for the same camera, and wonder if I can take the same approach--taking the camera apart (which I am a little reluctant to do) without some instructions.
Many thanks for any help.
  • melcon Jan 08, 2008
    I have the same problem with my Canon S 80 . My lens will not retract.
    Melissa
I have the same camera and had this problems today. My son solved the problem for me. He put his thumbs on each side of the lens and pressed inwards causing the lens to pop out. Since then, I have been able to close and open the lens repeatedly without any problem. Hope this works for you. Good Luck!
Syed
Posted on Jan 30, 2009
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
My Canon G6 strap got caught on the handle of a drawer causing me to loose hold of the camera. It swung and crashed into the cabinet. The lens is stuck in its extended position and doesn't retract when...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Oct 22, 2010 | Canon PowerShot G6 Digital Camera
Lens Error
If you are sure that your battery is fully charged but still does not do any good, then do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Nov 11, 2009 | Canon PowerShot A550 Digital Camera
My canon camera in not working the lens is stuck i drop it on the lens fram? how do i fix this?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot SX110 IS Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera got stuck
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Mar 12, 2009 | Canon PowerShot S80 Digital Camera
Canon powershot s80
Marcus, usually this is caused by some dirt or some parts of the lens mechanis may have been derailed due to impact or brakage.
what you want to do here is turn the camera on, and gently nudge the lens left to right or up and down.
if this did not work, you may also try to push the lens inwards or pull it out, just to check if the lens is stuck or the motor to make the lens go in and out is not operational anymore...
if you have more questions just lemme know
Sep 30, 2008 | Canon PowerShot S80 Digital Camera
Lens error
Hello
Regards
Andrea
Jul 13, 2008 | Canon IXUS V2 Digital Camera
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens
Switch off and on again? Take battery out and replace. Thats the only 2 ways of 'restarting a camera that I know of. Does your model have a 'reset' function? You will have to check the manual for that. Or ask Canon support.
Aug 22, 2007 | Canon PowerShot A460 Digital Camera
Canon PowerShot S80 Digital Camera Logo
632 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
