Question about SanDisk Sansa e260 MP3 Player
Connceting to computer
I hooked up my sansa sandisk e260 in msc mode and it comes up but whan i open it there is no music folder and the video folder and the pic folder are empty but there are things in the folders i can watch and see them whan its not hooked up i cant put any music on it of anything eles the converter does not pick up the device what can i do??
  • 1 more comment
  • beezyy Nov 30, 2007
    that helped me to be able to put music on it thank you but the converter still will not pick up device so i cant put videos of pics on it .
  • Red_Tang0 Nov 30, 2007
    I hav the same problem but i tried putting in the :\MUSIC on the disk drive bit it didnt work at all
  • Guest Sansa Mar 31, 2008
    i have the same problem it wont allow me to put any new music on it
Type in (drive here):\MUSIC to access the music folder or ..VIDEO for video folder. Then it acts like a hard drive.
Posted on Nov 30, 2007
I managed to work it out now thanks , i have the same problem as u beezy
    I went on :Tools,folder options,View and show hidden folders and files to see them again
SOURCE:
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...run the programs follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
How do i delete all the songs off my sansa e260?
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselfs then format a couple of times hope this works
Try and drag and drop from your music folder to the media folder on the player make sure usb mode is msc this will show you all the folders Use your windows explorer for the transfer... much easier...If you don't have copies of your music copy to a folder on the computer2.gif first
Dec 20, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa e260 player works fine, plays my music and everything, but I have a problem with adding/deleting music. When I connected it to my computer, it did not recognize the player and it did not show up...
MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion..... make sure your usb 2.0 driver is installed..Syncing to wmplayer puts music in the mtp music folder. change usb modes again and use the explorer to see the sansa msc lets you sync any Q/A IM or email me @ [email protected]
Jun 23, 2010 | SanDisk Sansa e260 MP3 Player
Music Playback
open explorer and go to tools, folder options, view, click on don't show hidden files2_bing.gif or folders, click on hide ext and hide protect click apply... Format mp3 player2_bing.gif and tranfer music back to the sansa You can make another music2_bing.gif folder (music1)put music in this....Keep it on msc this reads expansion cards and the sansa USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter
Apr 04, 2010 | SanDisk Sansa e260 MP3 Player
How to put music in a sandisk sansa
Download the Manua; after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer2.gif is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
You can make another music folder (music1)put music in this....
Oct 25, 2009 | SanDisk Sansa e260 MP3 Player
Hi I bought scandisk e260 without cd, when I connect it to the computer, the computer ask me to locate driver. Where can I get driver? thanks
Try connecting it to another computer and see if it will recognize it as sansa or removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansa and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier Make sure USB mode is MSC I use my computer to drag and drop my music from my music folder to the sansa media folder.... Open my computer click on folder what ever folder has your music in it and drag to media folder and drop (click on the (+)where it say's sansa ) easier not to sync
Apr 19, 2009 | SanDisk Sansa e260 MP3 Player
MY SANSA ISNT RECOGNIZED BY MY PC!
Apr 14, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk won't play or download any video
go under settings, and then click usb settings thier should be three types auto format, msc, and mtp. try one mode and see if your music or videos comes up, on the computer until you have tried all three, your data should be placed under 1 of these modes
Jan 18, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
For everyone having e260 problems here is the answer. First make sure that you have your usb mode on msc before plugging in to the computer. Then go to folder options and select show hidden folders. You now have access to the music folders and can delete music. You can create a new folder or use the music folder for your music. To prevent future problems go to properties on the hidden folders and unhide them.
Jan 16, 2008 | SanDisk Sansa e260 MP3 Player
Music files
Hi. I hope this info would help: Your Sansa E260 has 2 modes: MTP (Music Transfer Protocol) and MSC (Mass Storage Class). Your Operating System recognizes each mode differently, and music files saved in one mode would not be seen when you switch to the other mode, and vice versa. Try switching to each of these modes, then plug it to your computer and browse the player. To switch modes, use the following menu navigation: Menu >> Settings >> USB Mode This would give the choice of MTP and MSC.
Apr 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
